12-22-2006 10:57 PM - edited 03-03-2019 03:09 PM
Hii
I want to change the BGP port 179 to some other one how can i do it..
12-23-2006 03:59 AM
Its TCP port. So it may not be changed.
12-23-2006 05:59 AM
Write a new BGP code in C language and compile it on your router. I guess that's the only way.
12-23-2006 12:22 PM
hi
when you write you proper code as Amit has mentionned , you have to think to make it operationnel with others core routers that are running native port 179, at that moment cisco can come to the rescue by providing the port-map command (specialy in PIX environment)as it does i.e to http when using sometimes 80 and other 8080.
