Cisco 1801 - Ping - Request Timed Out
offpister
Hello everyone,
I have a Cisco 1801 Router, but whenever there is anything plugged into the integrated 8 port switch for example two computers, I cannot get them to ping each other. All of the ports are on the same vLAN.
I am a Cisco newbie, so sorry if this question/query is really basic. Is there anyway I can test the integrated switch to see if it is faulty - what is the likelihood of this happening???
Any suggestions/solutions welcome.
Jonathan Worth.
Network Manager
Hesa Limited
17 Replies 17
I have upgraded to: (C180X-BROADBAND-M) Version 12.4(24)T3
The System Bootstrap version is: 12.3(8r)YH8.
Still getting intermittent pings and high output errors:
Router#show interface fastethernet1
FastEthernet1 is up, line protocol is up
  Hardware is FastEthernet, address is 0019.0684.cace (bia 0019.0684.cace)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 230/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 2 packets/sec
     1074 packets input, 273381 bytes, 0 no buffer
     Received 331 broadcasts, 0 runts, 0 giants, 0 throttles
     252 packets output, 28357 bytes, 0 underruns
     101 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Router#show interface fastethernet2
FastEthernet2 is up, line protocol is up
  Hardware is FastEthernet, address is 0019.0684.cacf (bia 0019.0684.cacf)
     reliability 198/255, txload 1/255, rxload 1/255
     201 packets input, 25083 bytes, 0 no buffer
     Received 58 broadcasts, 0 runts, 0 giants, 0 throttles
     676 packets output, 132468 bytes, 0 underruns
     481 output errors, 0 collisions, 2 interface resets
Reply from 192.168.2.32: bytes=32 time=1ms TTL=128
Reply from 192.168.2.32: bytes=32 time<1ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Not sure what to do anymore.
Thanks.
Jonathan.
That seems to indicate a faulty unit.
If you don't have a support contract to have it replace by Cisco, it's not expensive to buy one.
Sorry for the delay in replying. I have just opened up the Cisco 1801 Router and have found that the memory socket on the motherboard(?) is empty and was just wondering if this could be the cause of the problem?
If there is meant to be a stick of memory in the the socket, please could you advise me on what memory it takes.
Please let me know asap.
Thanks very much for your support.
Jonathan.
