clear policy-map counters
p.diaz
Can Everybody tell me how can I clear the counters of the policy-map statistics in an 7600 and the 1841 router?
thanks
10 Replies 10
Gregory Camp
clear counters FastEthernet0/1 (or any other interface)
hi Greg.
but that command doesnt clear the drops stadistics? tks
It should, what IOS are you running? Send me the output of sh policy-map int before and after clearing the counters.
You could bounced the qos policy config...take it out and put it back in.
Ran accross this too,
Routeur wouldn't clear the policy-map counters (sh policy-map int xx) when clearing the specific interface...
Try clearing counters for all interfaces, worked for me..
ie:
clear counters
!## Make sure you hit enter to confirm at this prompt : Clear "show interface" counters on all interfaces [confirm]
Good Luck
On my Cisco 2821 I used the following to clear the Service Policy counters on the Multilink interface.
clear counters mu1
or
clear counters multilink 1
Hopes this helps.
Chad
clear qos counters int XXXXBLA.BLA.BLA (as an example)
My prior response is on a 9K
This is the correct answer. "clear counters"
kesva.naidoo
The only way I could reset the policy-map counters on an interface was remove it from the interface and put it back on.
