configuring two T-1s on VWIC2-2MFT-T1/E1
lcaruso
Level 6
Level 6
I'm going to be swapping out a WIC-1DSU-T1-V2  for a new VWIC2-2MFT-T1/E1, going from one to two T-1s.
This is on a 2800 router running 12.4(23)
Can anyone share...
configuration examples for the two T-1 setup ?
commands to verify the installation (show me the two T-1s are successfully bonded and communicating as one logical entity) ?
any other tips ?
Thanks.
Collin Clark
Thanks much. I must have waited 30 seconds for a reply
In the example, what are the zeros for on the end of each serial interface?
Would that be channel-group 0?
Serial0/2/0:0 unassigned YES manual down down
Serial0/2/1:0 unassigned YES manual down down
Serial0/3/0:0 unassigned YES manual down down
Serial0/3/1:0 unassigned YES manual down down
Provider had brought up one T-1 weeks ago and finally says they have the second T-1 up now but fails to loop to 2801.
Since half of the bundle has been up, what commands would you recommend I use to prove the bundle and/or interfaces are correctly configured?
The are claiming CPE issue.
