ā11-14-2012 06:56 AM - edited ā03-04-2019 06:08 PM
Hello al
i have 2 routers 2821 with wic-2t serical card and 1921 with hwic-2t serial card
My question is - can i connect between those two serials card with serial cross cable ?
Thank
ā11-14-2012 07:18 AM
DCE to DTE connection will work just fine.
ā11-14-2012 09:56 AM
You can connect the two together but you will need to make sure one supplies clocking, and I am not sure on the media type but if you use RJ-45 make sure the pairs are flipped at the distant end.
For instance:
Router A
1-2-4-5
4-5-1-2
Router B
This is known as a T1 crossover
ā11-14-2012 12:52 PM
Yes, you can connect back to back using
Smart Serial DTE Interface To Smart Serial DCE Interface Crossover Cable.
Normally this is done for studying purpose.
I did purchase some of them last year from http://www.anthonypanda.com/?sp=&p=6&cat2=0&cat1=0&cat0=2&id=22&cat1=0&cat0=2&new=&more=&s=46b15dcbbdd425421eb3389650329c54ā©=en
