Bookmark
Subscribe
1144
Show PPP Queues
Mavrick25
Is there a document that references the output of the following command..
show ppp queues??
in IOS there are internal data structures that may or may not be documented for the end user.
You can find hundreds of commands and output that are either undocumented, obscure or confusing. In most cases the commands are hidden, but they can also be made visible occasionally.
It is normal (in my opinion) that cisco doesn't have an obligation to disclose all these internals meant for the TAC and engineering.
It seems to me that no errors are reported in the output above, so you should be fine.
paolo bevilacqua
What's your problem behind the question ?
The problem behind this quesstion is:
What does...
0 UNREGISTERED
1 4 Setup
2* 4 Timer
3 4 Cstate
4 4 Restart CP
5 UNREGISTERED
6 4 Hard Disc
7 4 Soft Disc
8 4 Packet
9 4 Auth Packet
10 4 Set LCP Open
11 4 Virtualize
12 4 Redirect
13 4 Forwarded
14 4 AAA Response
15 4 Static Bind
16 4 Virtual Profil
17* 4 Multilink Up
18 4 Multilink Down
19 4 Multilink Clea
20 4 Susp Encap
0 UNREGISTERED
1* 2 IPCP Packet
2 UNREGISTERED
3 UNREGISTERED
4 UNREGISTERED
5 UNREGISTERED
6 UNREGISTERED
7 UNREGISTERED
8 UNREGISTERED
9 UNREGISTERED
10 UNREGISTERED
11 UNREGISTERED
0 UNREGISTERED
1* 1 Add Route
2* 1 Remove Route
3* 1 Remove Top
4* 1 Remove Flag
5* 1 Neg Addr Add
6* 1 Neg Addr Remov
7* 1 DHCP Opt Add
8* 1 DHCP Opt Del
9* 1 IPCP UP
10 UNREGISTERED
11 UNREGISTERED
0 UNREGISTERED
1 3 Dynamic Bind
0 UNREGISTERED
1 0 Hook
Pre-processed Requests LCP: 4163 IPCP: 2607
PPP Request Failures: 0
PPP Hold Queue Drops: 0
IPCP Skipped - Add Route: 0 AddrAdd: 0 AddrRem: 0
PPP Handles: alloc[2102211] free[2085538] outstanding[16673]
MEAN
