ShamilaGul58174
the Cisco CPN Client for a long time to connect to a VPN Server. Now I've got a new machine with a Windows 7 64 bit. The Cisco VPN Client isn't avaiable in a 64 bit version. Cisco suggests to use Cisco AnyConnect instead because there'a 64 bit version avaiable. The problem: When I use AnyConnect on my new machine, I always get a timeout when I try to connect. So I've installed AnyConnect on the old machine for testing and there I get the same problem: connection timeout. When I use the CPN Client, everything works fine. How can I fix this problem?
3 Comments
balaji.bandi
can you please explain more? and share any screenshot or logs?
connection timeout? ( you connected to Server or lost connection and time out, or not able to connect at all ?)
what is the VPN client version, what is the ASA version code?
ShamilaGul58174
The problem is resolved new thanks for your quick response.
balaji.bandi
Glad all working as expected, we mark this as resolved now.
