Anand Kanani
Cisco has recently opened up a self-service tool to convert Juniper ScreenOS configurations to Cisco ASA configs.
https://fwmig.cisco.com/
It is open to all the users registered on the Cisco website.
Try it out and let us know your feedback.
Anand
21 Comments
mimomhaz333_2
Is there is any tool which offer conversion from SRX to ASA
Anand Kanani
This tool now supports the conversion of CheckPoint Firewall configurations to Cisco ASA.
https://supportforums.cisco.com/community/netpro/security/firewall/blog/2013/12/19/conversion-tool--checkpoint-fw-to-cisco-asa
Patrick Taylor
I tried to run the utility for our Netscreen 208s and got this error:
  Juniper ScreenOS to Cisco ASA Config Conversion Tool - ver 4.0
Task Started at 2014-02-21 15:54:01 UTC on the Server
STEP [1/*] Reading the Config File
STEP [2/*] Renaming Trust/Untrust to Inside/Outside Respectively
STEP [3/*] Defining Disclaimer
STEP [4/*] Checking VSYS Existence
STEP [5/33] Finding Basic Information
STEP [6/33] Finding VRs and Interfaces
STEP [7/33] Creating Interfaces
STEP [8/33] Creating Routes
STEP [9/33] Creating Networks - part 1 of 2
STEP [10/33] Creating Networkgroups - part 1 of 2
STEP [11/33] Checking Network Name Conflicts
STEP [12/33] Remove Unaccepted Characters From Network Names
STEP [13/33] Creating Networks - part 2 of 2
STEP [14/33] Creating Networkgroups - part 2 of 2
STEP [15/33] Creating Services - part 1 of 2
STEP [16/33] Creating Servicegroups - part 1 of 2
STEP [17/33] Remove Unaccepted Characters From Service Names
STEP [18/33] Creating Policies
SOME ERROR HAPPENED WHILE CONVERSION. THAT IS ALL I CAN SAY HERE
Conversion Task had some issues at 2014-02-21 15:54:05 UTC on the Server
Anyone else have this issue?
Anand Kanani
Hi Patrick
I trust that your query has been resolved over the unicast email on the mailer fwmig-feedback@cisco.com
Since it was specific to your configuration, I'm not revealing any details here.
Anand
derict
is this tools still available? I can't seems to access/load it ...
Anand Kanani
Hi Direct
There was a maintenance activity going on. It is up now. Sorry for the inconvenience.
Regards!
ankjain2
Is there a tool which will convert configs from JunOS to ASA. We are moving from SRX650 to ASA and the JunOS config is extremely long and complex.
Thanks.
Been trying to access to the link but got proxy error. Anyone facing the same issue?
Zul
Anand Kanani
Hi Zul
Pls try now. The system was under maintenance. It is up now.
Anand
sasabri01
appreciate  if u can help me to convert juniper router configuration to cisco router configuration.
araghav01
I am converting check point config to cisco asa and did make sure that all 8 files were included in zip attachment but tool kept throwing error "The Uploaded Config does not contain all the 8 files as mentioned in the Configuration Collection Procedure".
Tool doesn't work.
thanks
/Amit
araghav01
It appears that I had to zip files by selecting all and then right click on actual files to zip. Zipping whole folder will not work. there is a note also somewhere.
slicerpro
This is the conversion tool for checkpoints, where is the tool for ScreenOs?
slicerpro
Scratch that. There is a button for ScreenOS. This tool has made my job that much easier. I was looking at converting +7000 lines from ScreenOs to Cisco ASA. Now I don't have to bill anyone for the overtime. Did I say I looove this tool ? Keep up the good work team!
Shera
Hi Anand,
link https://fwmig.cisco.com/ shows
Page Unavailable - Server Unavailable Error 503"
is the service down?
