Bookmark
Subscribe
4147
help: problem to connect nexus 2000 to two nexus 7000 with vPC
sp2891311
Hello
We have a nexus 2000 connecto to two nexus 7010 as FEX.
I see this in first nexus
nexus-1(config)# sh fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
101        FEX0101                Online     N2K-C2248TP-1GE   JAF1437BRCA
but on nexus-2 i see same nexus offline
nexus-2(config)# sh fex
  FEX         FEX           FEX                       FEX
---       --------               Offline     N2K-C2248TP-1GE   JAF1437BRCA
I try to insert fex portchannel on vPC domani ( alredy active for network vpc) but i recive that error:
nexus-2(config)# interface port-channel 100
nexus-2(config-if)# vpc 100
ERROR: Error in performing configuration: Unsupported option for sap 167
in vpc I see:
sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Type-2 consistency status       : success
vPC role                        : primary
Number of vPCs configured       : 2
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     1
vPC status
id   Port   Status Consistency Reason                     Active vlans
10   Po10   up     success     success                    1
100  Po100  down*  Not         Consistency Check Not      -
                   Applicable  Performed
anyone can help me?
Ty
Jerry Ye
It is not supported in the current release.
jerry
8 Replies 8
Jerry Ye
jerry
ty soo much.
You know if this feature can be available on the next 5.2 relase?
Not that I am aware of. Short answer will be a "no".
jerry
In which release, this  feature will be supported?
Nothing i m aware of.
jerry
vldmegafondv
Hi, is this feature suppored in 6.1 release?
No, it is not supported in 6.1.
We tested this in our lab and it is possible. You have to make sure your 7K is licensed for it and you enable the FEX Feature set on the 7K
