03-15-2016 05:13 PM
I frequently assist customers to setup SCH and the information from this community has been very helpful. Now, I´m facing the challenge that my customers have devices under ETSOP and C4P contracts and have found that there are some differences on how the configuration, registration and creation of service request processes work. I´d like to confirm if my assumptions/conclusions are correct or if there is something that can be optimized.
For ETSOP contracts:
1. No need to associate customer´s CCO Id to the contracts.
2. Devices are "automatically" registered after the inventory is sent to Cisco. There is no security token nor "complete registration" e-mail, so customer only needs to make sure SMTP server is working.
3. Partner (in this case VCE), needs to add the e-mail address to which the Partner SR request is forwarded
My question here is if customer is able to see the devices under ETSOP contracts in the SCH portal using their own CCO Id?
For devices in C4P contracts
1. CCO id needs to be associated to contracts
2. CCO id needs to be added to the "customer id" field in device configuration
3. After the inventory is sent, customer will receive 2 e-mails, one confirming Cisco received the device inventory and other with the information to complete registration (security token)
4. Customer has to login with the CCO Id associated to the contracts and complete registration
5. Customer now can see the registered devices with his Id and can add other CCO Ids to see/manage their devices
My questions here are:
- Can the same customer´s CCO Id see both type of devices, the one covered by ETSOP contracts AND the ones covered by C4P contracts?
- Can I see both type of devices with my Partner CCO Id?
Thanks is advance for your feedback.
03-28-2016 07:45 AM
Thanks for your question.
ESTSOP is a collaborative-based contract. C4P is a direct-based contract. In an ideal situation, a partner can see ETSOP devices, while a customer can only see C4P devices--unless both contracts belong to the same company. Smart Call Home notifications are assigned per device contract type. The processes to register a device are different (as your customer has noticed) by contract type.
Check out our engineers' answers to your questions, below:
Let me know if you have any further questions.
Thank you,
Kelsey
08-12-2019 03:45 PM
Does anyone know if the CON-ETSOP SKU only allows for the customer to go thru the partner to open TAC cases? DO they have to go thru VCE??
08-12-2019 04:03 PM
Based on the sku the customer would work with VCE initially and VCE would work with Cisco if they could not resolve the issue. Generally, in most cases, VCE opens a case for their customer-related issues.
I hope this helps answers your question.
08-12-2019 04:20 PM
08-12-2019 04:41 PM
Based on what was explained to me that because of the contract service level ETSOP - ETSP 24X7X4OS (24X7X4OS) and Reg Type "COLLABORATIVE_SERVICES", no registration confirmation is required. As an end result the customer will not be registered nor have visibility from the SCH portal, VCE partners will.
I'll need to confirm if anything has recently changed, but this is as per my case interactions with the above service level.
08-12-2019 04:46 PM
