Smart Call Home https url resolution yields an IPv6 address
michael.burke
  I have a couple of Catalyst 9300 Stacks licensed DNA/Network Essentials.  One has managed to register and one is having difficulty logging the error "Fail to send out Call Home HTTP message"
  When I configure a nameserver on this stack telnet resolves tools.cisco.com 443 to and IPv6 address however using the same nameserver ping yields the IPv4 address and finally telnet to the IP address resolved by ping indicates an open socket.  We currently are not routing IPv6.
  Is there a way to force this system to yield an IPv4 address or will I need to change the call home address to and IP?   I'm worried that if I do this the IP will change one day and these switches will go unregistered with our Smartnet Account.
Cisco IOS Software [Fuji] (CAT9K_IOSXE), Version 16.9.2
SW#telnet tools.cisco.com 443 /source-interface vlan 44
Trying 2001:420:1201:5::A, 443 ...
% Destination unreachable; gateway or host down
SW#ping tools.cisco.com source vlan 44
Sending 5, 100-byte ICMP Echos to 173.37.145.8, timeout is 2 seconds:
SW#telnet 173.37.145.8 443 /source-interface vlan 44
Trying 173.37.145.8, 443 ... Open
9 Replies 9
michael.burke
Well go figure it resolved itself.  Even though my telnet to the url still fails.  This may have had something to do with our Radius authentication and the fact that prior to this Smart Net call home program our management vlan was not allowed to speak to the internet.  I'm sure we will have to come up with a better way of managing this either through a web proxy or SMTP.
Bcssi Network
This is still very much a problem for us.  We are running version 16.06.02 on our CSR1000 routers in AWS and call-home is trying to use ipv6 for smart licensing.   The only way I have found to work around the issue is to hardcode the ip address in the call-home destination. Changing the default "destination address http http://tools.cisco.com/its/service/oddce/services/DDCEService" to use an IP that it resolves too....  "destination address http http://72.163.4.38/its/service/oddce/services/DDCEService" but we CANNOT stay running like that with a hardcoded ip.
The router resolves the URL fine and pinging the url works; however, telnet using the name fails.   See below.
CSR-ROUTER#ping tools.cisco.com
Sending 5, 100-byte ICMP Echos to 72.163.4.38, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 46/46/47 ms
CSR-ROUTER#telnet tools.cisco.com
Trying 2001:420:1201:5::A ...
CSR-ROUTER#telnet 72.163.4.38 80
Trying 72.163.4.38, 80 ... Open
Having the exact same problem on Azure with CSR1000v and smart call-home..
I randomly stumbled upon a solution on IOS XE Version 16.12.2r (Catalyst 9300)
%SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart Software Manager (CSSM) : Fail to send out Call Home HTTP message.
conf t
(config)# call-home
(cfg-call-home)# http resolve-hostname ipv4-first
%SMART_LIC-5-COMM_RESTORED: Communications with the Cisco Smart Software Manager (CSSM) restored
conf t
(config)# call-home
This didn't resolve my problem .Any other ideas ?
solved the issue, Thanks!
Did not work for me as well.
I have to setup statically the IP address
(config)#ip host tools.cisco.com 173.37.145.8
huajia
Level 5
Level 5
I have same issue. still have this issue even when using
still get
#telnet tools.cisco.com 443 /source-interface vl 188
roger.aas
This is old, but I came across it when searching for something similar.
First, when doing telnet with a FQDN and the dns call resolves an IPv6 address it will try that. So if your network does not have IPv6 then use the /ipv4 flag to the command:
telnet tools.cisco.com 443 /ipv4
Second, what another user answered earlier you have to tell the call-home to do the same using the "http resolve-hostname ipv4-first" in the call-home config.
And thirdly, when call-home is set to use http, the http client on the box must be told what interface/vrf/whatever to use with the "http client source" global command. f.ex.:
http client source vlan 44
Remark that this is in addition to the source config you put in the call-home setup.
I hope this helps someone else looking for an answer.
Best regards,
Roger
