Bulk add subnets for discovery
Fredrick Willis
I have around 200+ subnets I need to add to be discovered. I do not have the time to manually add all of the subnets. I know there is an import option, however, it appears it only accepts .XML files. Is there not an easier way to bulk import subnets? Or at least a tool to convert my info to a XML file?
Fredrick Willis
Any news on this? It has been 4 days since my post.
Hey Frederick,
I just wanted to see if the attachment I sent you yesterday helped you with this request?
regards,
Hello Fredrick,
Unfortunately, CSPC only allows XML input for bulk subnet discoveries. However there isn't a tool on how to generate this XML and the specific formatting. The best way would be to create a sample XML discovery job, then use the "export settings button". Modify the generated XML code to include the rest of the subnets, then use the "import" button to upload your subnets.
If you have a support contract, you can also open a TAC case to receive additional assistance with the formatting of your XML code if needed.
Cesar
