04-29-2021 06:04 AM
We would like to have the option to get licensing information from SSM via API.
I've seen in some slides that this should be available but I wasn't able to find any documentation on it.
Does anyone know if it's available and where can I find some API docs?
Thanks!
05-20-2021 08:54 AM
Hi pasha,
Looking for some details around it, will get back with an update.
Thanks & regards,
Devashish Bourai.
05-21-2021 07:06 AM
There aren't many documentations.
APIs are usually for customization and is for the customer to do on their own. We just help them onboard for that so that they can use it.
Refer to this, if it may help you. Link: Cisco API Documentation - Cisco DevNet .
Thanks & regards,
Devashish Bourai.
