CSPC and PSS role
Can someone explain me how can we get software / license report from CSPC.
Justin Sprake
The CSPC does not pull any software license data from devices and this capability is not within the scope of SNTC or PSS.
Hi Justin,
Thank you for you response.
Could you please check the below thread and let me know if this works on CSPC if I add the mib.
https://community.cisco.com/t5/network-management/how-to-get-router-or-switch-license-information-using-snmp/td-p/2703549
Saurabh
In short, unless the MIB is supported by both the CSPC and the Smart Portal it will not return any meaningful results. Based your desired outcome it sounds as though the type of information you are seeking is enabled as part of Smart Licensing and the Smart Account portal.
If your managed devices contain that particular MIB, you may be able to parse that data manually or through a self-maintained solution. You can SNMP walk to specific MIBs in a number of ways, but unfortunately, neither the CSPC nor the Smart Portal support the following MIBS:
1.3.6.1.4.1.9.9.359
1.3.6.1.4.1.9.9.543
Hello Justin,
Any solution that leverages the CSPC available data to confirm the Cisco licensing for renewal.
Saurabh
