CSPC Collector - Hyper-V Support
Added Solucoes
Cisco CSPC Collector is supported on Hyper-V?
Thanks in advance.
Luciano.
yes, as @adias told, the specs are the same
Jaderson Pessoa
*** Rate All Helpful Responses ***
9 Replies 9
Jaderson Pessoa
Yes it is... i'm using it in HYPER-V.
Jaderson Pessoa
Hi Jaderson,
Have you installed the ISO image for appliance available on CPSC download page or other method for installation?
Thanks in advance.
We do not have an official Hyper-v image but you should be able to deploy using the ISO image.
see below attachment.
Using the ISO image located at :
https://software.cisco.com/download/home/286312935/type/286312958/release/2.8.1.4
we have used ISO image.
This step can help you to install it using ISO: https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-ISO-Image-Installation-Guide.pdf
Jaderson Pessoa
What the hardware requirements,  can I asume the same requirements for a Vmware installation?
Thanks in advance.
yes the specs are the same
Jaderson Pessoa
Thanks for everybody that help!
glad to help :)
Jaderson Pessoa
