CSPC Colletor does not get Serial Number
Jaime MATEUS Gomes
Hi Guys.
We have successfully installed Cisco Collector 2.7 on customer's premisses.
I did run the proccess to get equipment's information and the results were not good at all.
For somereason that i cannot explain, the serial number of ALL Cisco's Hardware does not appear on Collector Interface.
But, other information like Host Name, IP Address, Type, IOS etc. were all there.
I did run the process using SNMPv2.
Can someone please help-me with this issue?
Thank you so Much !
taywelch
You will need to turn on the duplicate serial number check in the Collector GUI:
Settings> Discovery settings> Serial number duplicate check
After you turn on this feature and run a new discovery the serial numbers will appear under managed devices.
Taylor
8 Replies 8
Chris Camplejohn
Don't worry about it. This was a specific design change in CSPC 2.7. Rest assured your serial numbers are collected and will appear in the SNTC portal once you upload and that data is processed in the SNTC portal.
In fact. The SNT Portal dosen't show anything either.
Please see the Attachments.
Images have been removed as they contained personally identifiable information.
Under Administration>Upload Processing in SNTC Portal you see there are no uploads. Have you sent an upload of your collected data on CSPC back to Cisco and the SNTC Portal? It doesn't appear so and that is why no data is there yet.
Yes I Did, but the collector show me a result like "Failed ".
Could it be some problem with Firewall Outbound Connection ?
Hello mateuscisco,
I can see that you did issue an upload attempt from the CSPC on our side, so your outbound access looks good.  However it seems your CSPC timestamp may not be currently up to date.
Can you please try running the CLI command "timesync" from the "admin" CLI Username?  This will request for a local or remote NTP server to configure and setup your timestamp.  After that, please try to issue a new upload.
Thank you,
Jarrett
Hi Jaime,
Please let us know if you need further assistance.  If not, please mark this as solved to close the conversation.
Thanks!
Cheri
taywelch
Taylor
Thank You Very Much, the issue has been solved!
