CSPC export = success but I don't see the export in "Upload Processing" on SNTC portal
Steve Rodrigue
I've run 2 export earlier today, I don't see them being processed on the SNTC portal. Is there an issue with the uploading of DATA at the moment?
The last Export I executed worked fine (I was out of the office when it occured). So we can consider this case "solved".  It auto-magically fixed itself. :D
Thanks for your support.
9 Replies 9
taywelch
Hey Steve,
In a private message can you send me the collector ID? You can find the collector ID in the GUI by navigating to Help>view/manage registrations> properties.
Taylor
Private message sent.
Hi Steve,
SNTC uploading is currently being impacted by bug CSCvk29179. I will be sure to keep you informed when we receive the next updates.
Kind regards,
Thanks for the update.
Hi Steve,
Thank you for your patience. A hot fix was applied last evening.  Please reissue the upload and allow some time for it to appear in the portal.
Cheers,
Cheri
Ok, I've just started an upload job. I'll check later if it worked.
Upload fails with error 400.
As root, please run the below command and report back if uploads still fail after.
#service cspc restart
Thank you,
Brandon
