07-24-2016 12:39 AM
Hi All,
i install a fresh CSPC collector (2.5) and when trying to upload the inventory i'm getting fail status.
the server is connecting to the internet via Proxy.
T-Shoot I've done:
1. verify that there isn't any deny packets in the FW.
2. verify that the proxy doesn't block.
i must mention that this is not my first installation but still i want all over the installation guide and view all the topics in the support.
after viewing some tips in the support I verify and done those changes after saw in the support :
1. adding to the hosts file the CSPC server IP Address.
2. verified the connectivity to CISCO PORTAL (72.163.7.138) with WGET and its OK.
output attached:
[root@ranms7srv ~]# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
--2016-07-24 14:20:08-- https://72.163.7.113/HeadEndWebAppServlet/
Connecting to 10.232.233.70:8080... connected.
WARNING: certificate common name “concsoweb-prd.cisco.com†doesn't match requested host name “72.163.7.113â€.
Proxy request sent, awaiting response... 302 Found
Location: https://sso.cisco.com/obrareq.cgi?wh%3DConn-Prod%20wu%3D%2FHeadEndWebAppServlet%2F%20wo%3D1%20rh%3Dhttps%3A%2F%2F72.163.7.113%20ru%3D%252FHeadEndWebAppServlet%252F [following]
--2016-07-24 14:20:10-- https://sso.cisco.com/obrareq.cgi?wh%3DConn-Prod%20wu%3D%2FHeadEndWebAppServlet%2F%20wo%3D1%20rh%3Dhttps%3A%2F%2F72.163.7.113%20ru%3D%252FHeadEndWebAppServlet%252F
--2016-07-24 14:20:11-- https://sso.cisco.com/autho/forms/CDClogin.html
Proxy request sent, awaiting response... 200 OK
Length: 13605 (13K) [text/html]
Saving to: “index.html.1â€
100%[=============================================================================================================================>] 13,605 --.-K/s in 0.001s
2016-07-24 14:20:12 (21.7 MB/s) - “index.html.1†saved [13605/13605]
please advise,
thanks
Solved! Go to Solution.
07-27-2016 08:48 AM
Hi Dawit,
Is your proxy modifying the certificate? Our upload server won't accept the connection if it does.
"WARNING: certificate common name “concsoweb-prd.cisco.com†doesn't match requested host name “72.163.7.113â€."
Also, what are the contents of your hosts file now that you've modified it?
Lynden
07-25-2016 07:11 AM
Hi Dawit,
How are you trying to run the upload from the collector? Where do you see the fail status?
Lynden
07-27-2016 08:42 AM
I've tried in two different ways:
1. using the run collection profile marking the upload to server.
2. using run upload profile.
the failed are in the backend stage.
07-27-2016 08:48 AM
Hi Dawit,
Lynden
