CSPC SNMPv3 did not work
we just installed a new SmartCollector at the customer side. Snmpv2 scans are running but snmpv3 not.
We disabled snmp-server commands on the switch (C3850) enabeld an configured it again. but it want work.
So we used a snmpwalk from Collector-CLI:
with snmp -v2c -> "snmpwalk -v2c.jpg"
snmpwalk -v3 -> "snmpwalk -v3.jpg"
The Switch we are using got following configration:
bbag101#sh run | i snmp-server
snmp-server group snmpv3-group v3 priv write snmpv3-write
snmp-server group snmpv3-group-smart v3 priv read snmpv3-read
snmp-server community ******** RO 10
snmp-server community ***********  RO 19
snmp-server location "HV1, DataCenter, M7, Floor 0"
bbag101#sh snmp user
User name: Leoniv3-SC
Engine ID: 80000009030000451D62A980
storage-type: nonvolatile        active
Authentication Protocol: SHA
Privacy Protocol: AES128
Group-name: snmpv3-group-smart
User name: Leoniv3-l3
Switch : cisco WS-C3850-48XS
If you can see our failure - we would be happy!
Thanks and regards!
Matthias
7 Replies 7
Supriya Patel
Could you please private message me 'collector id', customer name as well below to confirm if this issue is due to CSCvr06152.
Please private message me below as well:
From root, please run below:
# tcpdump port 161 -v
<Please run above while performing discovery>
# cat $CSPCHOME/cspc_logging.log
How many devices do you have in your network configured for SNMPv3?
Supriya
here is the tcpdump from customer.
Hope it helps!
[root@vuhv1smartcspc01 ~]# tcpdump port 161 -v
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
16:24:50.791393 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 92)
    vuhv1smartcspc01.leoni.local.41083 > vl111.bbag101.leoni.local.snmp:  { SNMPv3 { F=r } { USM B=0 T=0 U= } { ScopedPDU E=  C= { GetRequest(14) R=983682519  } } }
16:24:50.792888 IP (tos 0x0, ttl 253, id 39502, offset 0, flags [none], proto UDP (17), length 136)
    vl111.bbag101.leoni.local.snmp > vuhv1smartcspc01.leoni.local.41083:  { SNMPv3 { F= } { USM B=24 T=439537 U= } { ScopedPDU E= 0x800x000x000x090x030x000x000x450x1D0x620xA90x80 C= { Report(33) R=983682519  S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsUnknownEngineIDs.0=456067 } } }
16:24:50.793031 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 163)
    vuhv1smartcspc01.leoni.local.41083 > vl111.bbag101.leoni.local.snmp:  { SNMPv3 { F=apr } { USM B=24 T=439537 U=Leoniv3-SC } { ScopedPDU [!scoped PDU]60_65_28_43_50_66_fb_c5_ac_36_43_f3_c7_e6_8f_82_a3_41_2c_97_20_75_91_c9_07_81_0b_ab_43_5b_5a_a8_33_d5_86_8f_5a_59_92_3f_e4_4e_65_88_1d_97} }
16:24:50.794389 IP (tos 0x0, ttl 253, id 39503, offset 0, flags [none], proto UDP (17), length 162)
    vl111.bbag101.leoni.local.snmp > vuhv1smartcspc01.leoni.local.41083:  { SNMPv3 { F=ap } { USM B=24 T=439537 U=Leoniv3-SC } { ScopedPDU [!scoped PDU]e7_93_5a_82_ef_28_f2_b2_2e_68_43_62_fa_97_40_bc_6d_72_b8_d6_51_24_de_a8_da_eb_a3_97_cb_c3_2f_ee_4c_38_b5_c0_df_bb_fd_77_1e_96_a7_2a_b1_b4} }
HI,
Please create post under PSS community.
https://community.cisco.com/t5/partner-support-service/ct-p/5456-partner-support-service
Please click 'Discussion' tab under Create section.
Supriya
Hi Supriya,
do you think the PSS community is answering faster, I don't think so....
It is not about being faster.  The SNTC community is for END USERS that have SNTC service and processes for support are not the same.  Since your collector is a PSS service entitled. you must pursue support on that community where the proper partners and PSS community can be leveraged.  Additionally The Partner that supports that collector can open a TAC case with their proper PSS partner contract in case of additional support is needed from Cisco
OK, i would like to open a TAC - where can i find the SN of the SmartCollector?
I have sent the instructions on how to open a TAC case for PSS partners and their CSPC/portal related issues over private message.
