End of Life Report
joseph.lucchese
Hello, is there an end-of-life report to run in the SNTC portal? It appears there is only end-of-support.
npicard
Hello Joseph,
You can find a wealth of EoX information in the pre-defined Product Alerts report. It can be found in the Actions>Schedule Task section. Once you click the green plus sign (+) in the Schedule Task section, a window will pop-up with a list of available reports. Select the Product Alerts report and "Run Now".
Nathalie
