Entitlement file generation failed. Please try again. If the issue per
I'm having a problem generating a Collector Certificate. I keep getting the message
"Entitlement file generation failed. Please try again. If the issue persists, find help in the community."
May you please help? My CCO ID is luis-m-deslandes[at]telecom.pt
Kind Regards,
Luis
8 Replies 8
Please note that I have already tried several browsers -- Chrome, MS Edge, FireFox, Internet Explorer -- and the end result is always the same.
kaptanej
Hi ,
I am the in-charge of this post and I will be assisting you the issue shortly .
Please share the following details in PM (private message) so that we can proceed further on the issue :
  • Company Name
  • Customer Name
  • Customer CCO ID
  • Customer's Email Address
Thanks & Regards,
Kapil Taneja
As requested, I messaged you privately, yesterday. Did you get my message?
Hi ,
I got your PM , will contact you shortly via email .
Thanks & Regards,
Kapil Taneja
Hi!
Do we have any feedback regarding this? I have not received any e-mail or reply.
Hi Luis ,
I have dropped you an email on the mentioned email id provided by you . Please acknowledge the email sent to you so that we can proceed further on the issue .
Thanks & Regards,
Kapil Taneja
Hi Luis,
Here is the resolution summary that we provided to the customer :
  • Customer was not able to generate the entitlement certificate on the SNTC Portal .
  • Customer was asked for the Webex session so that we can troubleshoot on the issue .
  • Customer was added under wrong party id 385807694 which is not associated to the contract number .
  • Customer was disassociated from the wrong company 385807694 and associated with the right company 245567575.
  • We run the manual sync to sync the SNTC Portal .
  • Customer was asked to try generating the entitlement certificate .
  • Customer was able to generate the entitlement certificate .
  • Customer has given the confirmation for the case closure.
  • Hence, proceeding with the case closure.
Thanks & Regards,
Kapil Taneja
