Export to File with CSPC
Mahmoud
when I run ''run upload profile''  it said successful but I cant found it in upload processing as the newest one was two months ago
I tried to run it several time but with no change
9 Replies 9
Lynden Price
Hi Mahmoud,
Manually run uploads will show under Reports > Job Management Reports > Upload Run Now Jobs
Scheduled uploads will show under Reports > Job Management Reports > Upload Jobs
Lynden
thanks Lyden for your support
but my question is when I upload data to the cloud I cant see this data as my last one was two months ago
On the SNTC portal, when you go to Library > Administration > Upload Processing, you say that you aren't seeing an upload for over two months?
If you check the uploads on the collector (Reports > Job Management Reports > Upload Run Now Jobs), are they running successfully?
I can run the upload profile successfully from "Running Upload Profile Job" but cant access Upload Run Now Jobs
attached error screenshots
It looks like the GUI has lost connection to the server. Try rebooting the server and then view the jobs again.
I restarted and now I can see successful jobs at (Reports > Job Management Reports > Upload Run Now Jobs) as attached
but not at the cloud
Could you expand the latest job (Nov 6) and see if it completed successfully?
Yes I can see it completed successfully
On the SNTC portal (tools.cisco.com/smartservices) if you click Library > Administration > Upload Processing, do you see a job that came in on Nov 6? Did it finish processing?
