Is it possible to restrict Internet access for CSPC collector?
Andrii1
I only need to give access for updates and synchronization for CSPC collector. Where can I find a list of URLs needed for CSPC collector to work&
Ports needs to be verified to be open for specific services added to the CSPC collector in case of SNTCportstobeopenforSNTC.JPG
5 Replies 5
aibhatna
Hi Andrii1,
Hope you are you doing well
We are looking into the issue you posted. We will reach out to you soon with an update.
Thank you
Aishwarya Bhatnagar
Hi Andrii1,
Since you need to give access for updates and synchronization for CSPC collector, here is the guide for the reference where you can find the access to be given. Please refer to page 11: https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Quick-Start-Guide.pdf
Thank you
Aishwarya Bhatnagar
Thank you so much!
Hi Aibhatna,
Thanks for your answer! In question i mean access to internet (not internal).
