Java error when logging into the CLI via user admin? - error attached
systemamfry
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.05.17 13:55:47 =~=~=~=~=~=~=~=~=~=~=~=
login as: admin
                                           CSP Collector
Please use below url to access CSP Collector appliance GUI
IPv4 URL : https://xxx.xxx.xxx.xxx
Using keyboard-interactive authentication.
Password:
Last login: Thu May 17 14:06:14 2018 from xxx.xxx.xxx.xxx
#     This system is hardened and for the use of authorized users only. #
#     Individuals using this computer system without authority, or in   #
#     excess of their authority, are subject to having all of their     #
#     activities on this system monitored and recorded by system        #
#     personnel.                                                        #
#     In the course of monitoring individuals improperly using this     #
#     system, or in the course of system maintenance, the activities    #
#     of authorized users may also be monitored.                        #
#     Anyone using this system expressly consents to such monitoring    #
#     and is advised that if such monitoring reveals possible           #
#     evidence of criminal activity, system personnel may provide the   #
#     evidence of such monitoring to law enforcement officials.         #
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/log4j/Logger
                at com.cisco.ca.ss.lcm.adminshell.client.ShellClient.<clinit>(ShellClient.java:20)
Caused by: java.lang.ClassNotFoundException: org.apache.log4j.Logger
                at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
                at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
                at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349)
                at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
                ... 1 more
7 Replies 7
Justin Sprake
Could you confirm whether or not you have access to the 'collectorlogin' and 'root' accounts via CLI? It may be necessary to validate the installation of the last patch applied to the CSPC. Once you are logged in a 'collectorlogin', run the 'su' command to change to root.
If you can, please confirm the output from the below commands:
ls -larths /opt/LCM/tmp
tail /opt/LCM/logs/apply
I can no longer login via CLI as root or collectorlogin.
The previously attached error is from attempting to login to the CLI as user admin.
I can login to the GUI fine. It shoes apply in progress. version 2.7.4.1
Unfortunately, without access to the collectorlogin or root accounts troubleshooting this issue will be severely limited.
Can you restart the appliance and confirm whether the 'apply in progress' status is resolved?
No status change after restart...
Unfortunately, until CLI access is restored to Collectorlogin and Root, there will not be a method to evaluate the integrity of the patch files or the installation.
If the WebUI status does not provide an option to re-apply the patch either, the only viable solution here would be to redeploy the OVA.
I am recieving the same error  however I do have access to to the collectorlogin and root the password.
How can i resolve this issue ?
Mikey
Hi Mikey,
Thank you for reaching out for assistance. For visibility for our experts and for tracking purposes, please start a new discussion.
Cheers,
Cheri
