New Collector need help editing ip address range
mgayle083
I had an old version of the collector up and running about a year ago and it crashed, so I started over yesterday with 2.8, I entered the ip address ranges and the job is taking way to long to run so I would like to narrow it down a little. How can i edit that list? Thank you for any assistance you can provide.
Supriya Patel
For range based discoveries, it's recommenced to use Class C ranges. This will help with the overall discovery times. If you have known ip list available then I would try with those, that will be faster. There will be an option to have discovery with 'Discover device with known ip'.
Supriya
Thank you for the reply. Will that creat a job that can be scheduled or will that only create a one time job?
Make sure you set not to scan network and broadcast IP, you have some issue if network have some legacy stuff like UPS / Legacy Servers.
BB
