05-24-2017 01:58 AM
I have just setup a SmartNet contract for our equipment and the portal says it is setting up and check back later. It is well over the 24 hours and I cannot no anything.
What should I do?
Solved! Go to Solution.
05-24-2017 05:56 AM
Hello Steve,
I have verified that your account looks okay now, would you be able to please refresh the SNTC Portal and see if your access looks okay now?
Thank you,
Jarrett
05-24-2017 05:56 AM
Hello Steve,
Thank you,
Jarrett
05-24-2017 05:59 AM
Thanks, Jarrett. It is all set up now.
If you could fix all my other problems I'd be very grateful - lol. It isn't easy being a newbie in the Land of Cisco!
06-08-2017 04:04 AM
I have this problem too, any chance you could have a look at my account too?
This is a new setup, and the portal is still showing:
"Thanks for logging in, your account will be available within 24 hours.
Check back later."
Richard
06-08-2017 05:42 AM
Hello Richard,
Can you please check now and see if you're able to view the SNTC Portal?
Thank you,
Jarrett
06-08-2017 05:58 AM
thanks, that's sorted now.
Just adding my collector...
06-12-2017 07:32 AM
It's been 4 days and mine still says account setup in progress. I've refreshed to no avail.
Cheers,
Beers
06-12-2017 07:46 AM
Hello Todd,
We reviewed with the backend team, your access should be good now. Please give it a try.
Also, I suggest that you open a new thread. It makes it easier to follow up.
Cesar
06-12-2017 07:51 AM
Snd done. Grazie!
06-15-2017 03:51 PM
Cesar,
I got the same problem. Been 3 days now. Can you help?
Kenny
06-16-2017 06:07 AM
Hi Kenny,
Your account shows active now. Can you please verify.
In addition, I suggest that you make a new post next time as it's much easier to follow up that way.
Cesar
