SNTC Collector - TailEndGateway_Connectivity_Exception_occured
gabrielcastano
Hello, we have a problem when uploading the file of the scheduled task. The message error is TailEndGateway_Connectivity_Exception_occured
The version is 2.11, we did a new installation because we were with the 2.8 version, we created the backup file and restored all the configuration.
Also, when we try to access to "Software Updates -> Server connection setup" and we put the credentials that page freezes and does nothing.
I attach two images, one with the error and the other with a ping test
gabrielcastano
Hello, we did a new installation with a new entitlement, and then we had to do troubleshooting in the firewall, the collector needs to connect to the IP 72.162.7.113 on ports 80 and 443.
AltaNoc NSG
Getting the same error. Have tried generating new entitlement, reloads, set upload to disabled-reboot-then back to connectivity. Still fails.
network.sdsla
Have you guys solved this issue? If so, please let me know.
gabrielcastano
