SNTC Portal Access
petey1984
I am trying to access Cisco Services Access Managment page, however I see the following error:
"You are not authorized to access this resource"
Peter
5 Replies 5
Adrian1978
I have the same problem.
I had got a mail "Order Completion Notification...." from Cisco, with a link "Download Order Completion Report" an when i try to follow this link i get the same error "You are not authorized to access this resource".
I´m the company administrator, so i think i have the permission. What do i wrong ?
Kind Regards,
Adrian
Can you please provide the URL you have? I do not believe it's related to CSAM/SNTC.
Thank you,
Jarrett
Hello Jarrett,
this is the URL i had got Download Order Completion Report
Adrian
Hello Adrian,
Thanks for your URL - I can see this is now related to CSCC and not CSAM/SNTC.
You may wish to open a case with the CSCC team regarding your issue on the My Cisco Workspace page here -> https://www.cisco.com/cisco/psn/web/workspace
Thank you,
Jarrett
Jarrett Pomeroy
Hello Peter,
You currently do not have any roles assigned within the CSAM Portal. Your DA will need to assign either CustomerAdmin or CustomerUser SNTC roles so that you may access the SNTC Portal a https://services.cisco.com/.
If you wish to view the CSAM Portal, your DA can grant you additional Admin (DA, Role Administrator) type roles. These are separate from SNTC.
Thank you,
Jarrett
