unable to collect or upload
tech_nw
we are trying to install and configure the CSPC, we are able to entitle the server but the automatic upload fails with a generic internal server error, and in there's no menu or view to manual upload the collection via web.
I suppose something wrong with the configuration or on the association of the SNTC with our account.
Can someone explain where start to check?
The server is registered and I can see the version on the portal services.cisco.com, version 2.8.1.6.
adias
Thank you in looking at the logs the more specific error found is -->
[className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=625][isRemote=false]: message: Send File failed,http status code:404
Please at the root Prompt do the following and let me know
Via SSH Login to collector as user collectorlogin and then use command below to connect as root (cannot connect directly)
# su root
and then the following commands :
# sed -i ':a;N;$!ba;s/file/#file/1' /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/run.sh
# sed -i 's/nettools-upload.cisco.com/72.163.7.113/g' /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
# service concsotgw restart
# service cspc restart
Once they are done try the collection profile/upload again
REF : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo43779
6 Replies 6
adias
You mentioned you are unable to "collect" did the collection profile failed or just the upload module of it?
Re: Unable to upload Inventory - Internet Server Error
OK for troubleshooting please do the following :
We will need to connect via ssh to the user collectorlogin and then su to root
if you only have access to the admin cli user you can activate and generate the passwords with the commands below
If you do have have that access connect via SSH using the admin user and its passwords ad do the following :
admin#  pwdreset collectorlogin 90
and
admin# pwdreset root 90
If you already have access to collectorlogin and root access do the following
Connect to the user via ssh collectorlogin then su to root as shown below
$ su root
and then send me the output of the following commands on a private message.
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
Thanks for your support.
From my understanding, the issue could be on the upload module.
I'm sending the log by private message.
adias
# su root
Thank you!
Seems it worked, the job on the server was completed without any fail, but I'm not able to see the data on the cisco portal.
Where I should find the information?
I tried to open the service.cisco.com but after the collection, I see a blank page and nothing else I tried to change pc, internet line and browser without success, always a blank page
The initial upload to Cisco takes a bit longer to process, please check again and let us know if the issue has been resolved from your view as we can confirm your upload has completed end-to-end processing.
Thank you
Its working, thanks for your support!
