Collector Upload fails HTTPs TransportMode has Failed 404:Not Found
darshanj
CSPC ver 2.8.1.4
I'm getting the following error  at the upload phase:
CSP0009043224: A connectivity exception occured while processing the request. The Exception is :: HTTPs TransportMode has Failed 404:Not Found
See job report below:
Phase Name
Phase Status
Message
INITIALIZING
SUCCESSFUL
SELECTING_DEVICES
SUCCESSFUL
1 devices selected
SEGMENTING
SUCCESSFUL
EXPORTING
SUCCESSFUL
transport-inventory-1571273594487.zip
UPLOADING (CSP0009043224)
FAILED
CLEANING_UP
SUCCESSFUL
Any ideas how to resolve this problem ?
Darshan
Re: Unable to upload Inventory - Internet Server Error
OK please do the following :
We will need to connect via ssh to the user collectorlogin and then su to root
if you only have access to the admin cli user you can activate and generate the passwords with the commands below
If you do have have that access connect via SSH using the admin user and its passwords ad do the following :
admin#  pwdreset collectorlogin 90
and
admin# pwdreset root 90
If you already have access to collectorlogin and root access do the following
Connect to the user via ssh collectorlogin then su to root as shown below
$ su root
and then the following commands :
# sed -i ':a;N;$!ba;s/file/#file/1' /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/run.sh
# sed -i 's/nettools-upload.cisco.com/72.163.7.113/g' /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
# service concsotgw restart# service cspc restart  Once they are done try the collection profile/upload again
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo43779
adias
perhaps do you have CLI via ssh access to the user collectorlogin and root?
yes i do have access
and
$ su root
Thanks that worked !
