10-06-2017 03:26 AM - edited 03-12-2019 07:30 AM
Hi Guys.
We have successfully installed Cisco Collector 2.7 on customer's premisses.
I did run the proccess to get equipment's information and the results were not good at all.
For somereason that i cannot explain, the serial number of ALL Cisco's Hardware does not appear on Collector Interface.
But, other information like Host Name, IP Address, Type, IOS etc. were all there.
I did run the process using SNMPv2.
Can someone please help-me with this issue?
Thank you so Much !
Solved! Go to Solution.
10-06-2017 06:32 AM
You will need to turn on the duplicate serial number check in the Collector GUI:
Settings> Discovery settings> Serial number duplicate check
After you turn on this feature and run a new discovery the serial numbers will appear under managed devices.
Taylor
10-06-2017 04:09 AM
10-06-2017 06:04 AM - last edited on 10-06-2017 09:04 AM by Cheri Fairbrother
In fact. The SNT Portal dosen't show anything either.
Please see the Attachments.
Images have been removed as they contained personally identifiable information.
10-06-2017 06:14 AM
10-06-2017 06:24 AM
10-06-2017 06:32 AM
Hello mateuscisco,
I can see that you did issue an upload attempt from the CSPC on our side, so your outbound access looks good. However it seems your CSPC timestamp may not be currently up to date.
Can you please try running the CLI command "timesync" from the "admin" CLI Username? This will request for a local or remote NTP server to configure and setup your timestamp. After that, please try to issue a new upload.
Thank you,
Jarrett
10-11-2017 02:06 PM
Hi Jaime,
Please let us know if you need further assistance. If not, please mark this as solved to close the conversation.
Thanks!
Cheri
10-06-2017 06:32 AM
Taylor
10-18-2017 02:20 AM
