CSPC Upgrade to 2.7.4 Stuck in "Downloading"
rdruhland
Currently used the GUI to upgrade and have let it sit for 24 hours.  After that I have logged in to the admin shell and get the following output when running a "show download progress"
admin# show download progress
Package Name Package Status Downloaded Percentage
sp-30.0.4-0-0-lnx64 Downloading 1
admin# download sp-30.0.4-0-0-lnx64
Requested package is already downloaded and applied.
I saw in https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-ReleaseNotes-2732.pdf that there is a way to reset the status but I'm not sure if the carriage returns carry over from the doc and am wondering if this is still a process I can use to cancel the download and try to start it from the CLI.
Jarrett Pomeroy
Can you please let me know if you initiated the upgrade from the GUI or CLI? It shows that the patch may have already been attempted. Can you please provide me the output of the command "show ver -d".
Thank you,
Jarrett
adias
You are correct the PDF file has some formatting issued for this reason to avoid the problems in the document I attached the following file which shows the line by line. But that above command should still be valid depending on the present version since older versions use a different database than Derby. The command it is a derby database tool command and you would had to connect to it from a derby prompt once you apply the line commands that are delineated on the release notes document for 2.7.3.2 prior to issue the command. If successful you should had given you a prompt like ij>.
In any case prior to attempt that command in specific
Issue the following commands and send the output to us.
FROM ROOT USER
# tail -150  /opt/LCM/logs/install
and
# env | grep proxy
and
# ls -lart /opt/LCM/tmp/
and
# ls -lart /opt/LCM/tmp/downloads
FROM ADMIN USER
admin# show version -d  ( already asked by Jarrett above)
admin# show downloads
admin# show apply
===========Admin Output=============
Build-name : Collection Platform Software 2.7.3.2
Package-type : ServicePack
Version : sp-30.0.3-1.2-0-lnx64
Component : CSPC Base
Version : 2.7.3.2
Package-type : JeOS
Version : jeos-30.0.3-1.2-lnx64
Component : AdminShell
Version : 1.6
Component : LCM
Version : 1.6
Component : CASP
Version : 2.7.3.2
Component : ConcsoTgw
Version : 1.7
Component : Hardened CentOS
Version : 6.8 patch#0
Version : sp-30.0.3-0-0-lnx64
Download Location : /opt/LCM/tmp/sp-30.0.3-0-0-lnx64-package.zip
Status : Downloaded
Start Time : Jan/16/2018 15:17:04
End Time : Jan/16/2018 15:29:44
Reason For Failure : -
Version : sp-30.0.3-1-0-lnx64
Download Location : /opt/LCM/tmp/sp-30.0.3-1-0-lnx64-package.zip
Status : Downloaded
Start Time : May/25/50060 05:43:55
End Time : Feb/06/2018 14:08:50
Version : sp-30.0.3-2-0-lnx64
Download Location : /opt/LCM/tmp/sp-30.0.3-2-0-lnx64-package.zip
Status : Downloaded
Start Time : Nov/28/50166 17:26:00
End Time : Mar/13/2018 09:39:29
Version : sp-30.0.4-0-0-lnx64
Download Location : -
Status : Downloading
Start Time : Aug/19/50202 04:26:49
End Time : -
admin# show apply
Version Number : sp-30.0.3-0-0-lnx64
Status : Applied
Start Time : Jan/16/2018 15:30:14
End Time : Jan/16/2018 16:17:55
Version Number : sp-30.0.3-1-0-lnx64
Status : Apply-in-progress
Start Time : Feb/07/2018 08:44:44
End Time : -
Version Number : sp-30.0.3-2-0-lnx64
Start Time : Mar/13/2018 09:50:45
End Time : -
admin#
===========Root output======================================
[root@cspc ~]# tail -150 /opt/LCM/logs/install
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/buggy_device_versions.txt 100
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/.. 77
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/discovery-cso-build.properties 105
5: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/. 76
6: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/discovery-module-registry.xml 104
7: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/discovery_mask.properties 100
8: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/discovery-cso-log4j.properties 105
9: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/cli_discovery_os_mapping.properties 110
10: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/discovery-cso-startup.properties 107
11: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/discovery_ping.properties 100
12: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/properties/snmpinfo.dat 87
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/. 65
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/idu 67
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/idu/.. 70
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/idu/feature-mapping.xml 87
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/idu/idu-mapping.xml 83
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/discovery/idu/. 69
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel 60
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/.. 63
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg 63
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/.. 66
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/ASNLP00000211ks 79
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/aesencryption.properties 88
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/proxyconfig.config.update 89
5: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/aesnewencryption.properties 91
6: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/tg.properties 77
7: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/encryption.properties 85
8: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/connectivity_service_feature_mapping.properties 111
9: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/. 65
10: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/desencryption.properties 88
11: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/proxyconfig.properties 86
12: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/distlist 72
13: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/tg/datatransfer.properties 87
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/snmp 65
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/snmp/.. 68
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/snmp/. 67
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/snmp/snmponjava.properties 87
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/snmp/snmp_physical_address_oids.txt 96
5: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/snmp/snmpinfo.dat 78
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/. 62
5: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/osnames 68
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/osnames/.. 71
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/osnames/replacement_os_names_mapping.txt 101
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/kernel/osnames/. 70
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/. 55
5: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server 60
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/.. 63
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/tranport_mapping.properties 88
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/. 62
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/syslogparser 73
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/sysNumber of arguments = 2
Argument array2: [/opt/cisco/ss/adminshell/applications/CSPC/ppm/cspc_cp_2.7.3.2_Build3_linux.zip, apply]
Number of arguments to the class 'com.pari.patch.PatchMain is 1
ARGS[0] =/opt/cisco/ss/adminshell/applications/CSPC/ppm/cspc_cp_2.7.3.2_Build3_linux.zip
ARGS[1] =apply
server/kernel/server.jar .. unpacked
catalog.xml .. unpacked
patch.xml .. unpacked
PASSED BASE DIR = /opt/cisco/ss/adminshell/applications/CSPC/ppm/bin/../patches/cspc_cp_2.7.3.2
BASE DIR = /opt/cisco/ss/adminshell/applications/CSPC/ppm/patches/cspc_cp_2.7.3.2
----End of init----
----Begining of setProperties----
----End of setProperties----
----Begining of runTarget----
----log file location :/opt/cisco/ss/adminshell/applications/CSPC/logs/ppm_logging_cspc_cp_2732_1520963598972.log
----Please wait for few mins for installation to complete......
Getting process exit code
WARN |
INFO | Cspc Helper Server : Waiting to make sure that main process is started.............
INFO | Cspc Helper Server : Connection to main server established.
----End of runTarget----
logparser/.. 76
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/syslogparser/syslogparser.properties 97
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/syslogparser/. 75
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/syslogparser/ReadMe.txt 84
5: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/external_services.properties 89
6: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/mainserver 71
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/mainserver/.. 74
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/mainserver/helperlog4jconf.properties 98
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/mainserver/mainserver.properties 93
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/mainserver/. 73
7: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/datastore 70
8: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/tftp 65
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/tftp/.. 68
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/tftp/tftphost.properties 85
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/tftp/. 67
9: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/backup_resource_config.properties 94
10: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/server/appVisibilityConfig.properties 91
6: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity 66
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/.. 69
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/properties 77
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/properties/.. 80
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/properties/build.properties 94
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/properties/. 79
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/properties/messages_en_US.properties 103
5: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/properties/pubsub.properties 95
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/. 68
4: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/resources 76
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/resources/.. 79
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/connectivity/resources/. 78
7: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/applicationdiscovery 74
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/applicationdiscovery/appdiscovery_conf.xml 96
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/applicationdiscovery/.. 77
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/applicationdiscovery/. 76
8: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/sshserver 63
1: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/sshserver/ssh_server.properties 85
2: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/sshserver/.. 66
3: Directory Entry is /opt/cisco/ss/adminshell/applications/CSPC/resources/sshserver/. 65
Number of JVM Arguments 2:RETURN VALUE IS : 0
CSPC is upgraded to 2.7.3.2
Checking CSPC Service status
CSPC server started
Inside CSPC base install script
Started execution of post-install scripts in package sp-30.0.3-2-0-lnx64 ...
Finished execution of post-install scripts in package sp-30.0.3-2-0-lnx64 ...
jeos-30.0.4-0-lnx64.zip ==========
[Mon Mar 26 09:33:11 CDT 2018] Starting download operation
jeos-30.0.4-0-lnx64.zip ++++++++++++
ASD-DOWNLOAD: Getting File details from the server
-==https://concsoweb-prd.cisco.com/lcmdownload/?dwnld_code=xhMnkw8Z-oGUCa0SF-5fpsoPHQD-_fY4L1TguMo0sQIuV3FwE5HcUw30rmt6tKY2e0lt_vjwoCmrsi5hvN0JaUmAfYTG_B8n9fBtWltEsDxCOpdmWwSNQ6Jm3uo-JSvNhrhRFUAq1enppVY0JpYWQW63DK--qx05GlirEaf_AwfoREQptiA-PHkpLNJorq8S&a...>>>>>
/opt/LCM/tmp/downloads/jeos-30.0.4-0-lnx64.zip~~~~~~~~~~~~~~~~~~
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
107 859 107 859 0 0 2560 0 --:--:-- --:--:-- --:--:-- 14316
ASD-DOWNLOAD: Removing temporary files...
sp-30.0.4-0-0-lnx64.zip ==========
[Mon Mar 26 09:33:12 CDT 2018] Starting download operation
sp-30.0.4-0-0-lnx64.zip ++++++++++++
-==https://concsoweb-prd.cisco.com/lcmdownload/?dwnld_code=xhMnkw8Z-oGUCa0SF-5fpsoPHQD-_fY4L1TguMo0sQIuV3FwE5HcU4KLZ9Evon8ZkIjGesyhfCS0Uqw_H7hKZ2UdN892MYM1exFh6E01Nbj_783RH8mEN5mojZ_rREynGKMvCbjl4MDOQo0JiIwfSFVdpMSwpWa_sB01M7bieTROYL_vo2BOluz8ZGNtY7k9&a...>>>>>
/opt/LCM/tmp/downloads/sp-30.0.4-0-0-lnx64.zip~~~~~~~~~~~~~~~~~~
107 859 107 859 0 0 3215 0 --:--:-- --:--:-- --:--:-- 16519
[root@cspc ~]# env | grep proxy
[root@cspc ~]# ls -lart /opt/LCM/tmp/
total 1388188
-rw-r--r--. 1 casuser casusers 1001002317 Jan 16 15:29 sp-30.0.3-0-0-lnx64-package.zip
drwxr-xr-x. 9 casuser casusers 4096 Jan 16 15:55 ..
-rw-r-----. 1 casuser casusers 164225387 Feb 6 14:06 sp-30.0.3-1-0-lnx64-package.zip
-rw-r--r--. 1 root root 707093 Feb 7 08:45 sp-30.0.3-1-0-lnx64.zip
-rw-r-----. 1 casuser casusers 246380898 Mar 13 09:36 sp-30.0.3-2-0-lnx64-package.zip
-rw-r--r--. 1 root root 9158909 Mar 13 09:51 sp-30.0.3-2-0-lnx64.zip
drwxr-xr-x. 3 casuser casusers 4096 Mar 26 09:33 .
drwxr-x---. 2 casuser casusers 4096 Mar 26 09:33 downloads
[root@cspc ~]# ls -lart /opt/LCM/tmp/downloads/
total 16
drwxr-xr-x. 3 casuser casusers 4096 Mar 26 09:33 ..
-rw-r-----. 1 casuser casusers 859 Mar 26 09:33 jeos-30.0.4-0-lnx64.zip
drwxr-x---. 2 casuser casusers 4096 Mar 26 09:33 .
-rw-r-----. 1 casuser casusers 859 Mar 26 09:33 sp-30.0.4-0-0-lnx64.zip
[root@cspc ~]#
