12-15-2017 02:36 PM - edited 03-12-2019 07:36 AM
I'm trying to setup the Server Connection. I'm using the same CCO ID/Password that I normally use. The firewall rule is open for ICMP, HTTP,HTTPS and FTP to any. I keep getting back that the CCO ID/Password is invalid.
Once I get by this step I will be doing the upgrade to 2.7.2.5
12-15-2017 02:54 PM
12-15-2017 02:59 PM
12-17-2017 02:50 PM
I am experiencing the same issue too with all the documented firewall destination & protocols open.
Below is the error i receive when trying to enable the update process on our CSPC:
Build-name : Collection Platform Software 2.7
Package-type : ServicePack
Version : sp-30.0.0-0-0-lnx64
Component : CSPC Base
Version : 2.7
Package-type : JeOS
Version : jeos-30.0.0-0-lnx64
Component : AdminShell
Version : 1.3
Component : LCM
Version : 1.3
Component : CASP
Version : 2.7
Component : ConcsoTgw
Version : 1.6.4
Component : Hardened CentOS
Version : 6.8 patch#0
conf serv enable
This operation will enable connection with server for Software Updates.
CCO Id : xxxxxxxxxxxx
Password :
Would you like to continue (y|n)? y
Unable to validate credentials.
Please try again after some time.
Please note for the destinations and protocols through the firewall we are using:
https://www.cisco.com/c/en/us/support/docs/services/sntc/cspc_troubleshooting.html
12-18-2017 07:15 AM
This appears to be an issue that is being tracked via the following bug ID - CSCvh19961.
No workaround is there as of now. I'll update if I hear back from the CSPC team regarding workarounds.
Cesar
12-18-2017 02:51 PM
12-19-2017 07:00 AM
Hello bbcstone,
It may take up to one day to become visible, can you please check again today?
Thank you,
Jarrett
