Adding new switch to old stack
SCOTT No2
We have 2 SG350x-48 switches in a stack.  and we need to add another switch.  but I know that SG350x-48 is no longer sold.  what are my options?  these were replaced by the "Cisco Business 350 Series Managed Switches".  can one of these switches be added into the stack?  or do I need to replace the entire stack? Or buy a used SG350x-48 switch?  other options?
Mark Elsen
     >... can one of these switches be added into the stack?
         - No ,
    >...Or buy a used SG350x-48 switch?
         Best advice  ,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
         - No ,
         Best advice  ,
  M.
       Beauty and terror
      Just keep going
       No feeling is final
balaji.bandi
Stacking Guide lines - until it states any where otherwise - hardware models and Firmware and IOS code should be same.
you are not worried about support - for temporary fix you can buy refurbished same model and join to stack.
when you have budget - replace with better model is wise for commercially and operationally.
BB
SCOTT No2
Thank you.  I'll have to check for a used switch.
