CBS350-8T-E-2G : how to use the SFP ports ?
daniel48
I have a new (for me) CBS350-8T-E-2G.
There are 2 SFP ports but i'can't connect them. They stay ever down.
How can we use them ?
You are trying to connect a 10G SFP+ DAC into a 1G SFP slot. The CBS350-8T-E-2G has 2 units of 1G SFP slots while the other switch, CBS350-8MGP-2X that works, has 2 units of 10G SFP+ slots. Your 10G SFP+ DAC will never work with the CBS350-8T-E-2G.
8 Replies 8
balaji.bandi
Some devices have combo ports like other enterprise :
Some SFP interfaces are shared with one other RJ-45 and SFP+ port, called a combo port. When the SFP is active, the adjacent RJ-45 port is disabled.
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/Administration-Guide/cbs-350/get-to-know-your-switch.html
BB
Thanks for the answer,
OK, but i try to connect the SFP+ on port 9 (port 9 rj45 is free) to a router (in fact a internet box) with a dac and that doesn't work.
It works only if i connect a rj45 port to the box as source.
I don't understand why ...
Maybe the DAC is not supported in this case. Just try "normal" modules with the same spec on both sides and a short cable. I never used DAC cables between different vendors or different device classes.
I have CISCO CBS350-8MGP-2X and NETGEAR MS510TX linked with a DAC cable. Both are SFP+ and the link works just fine.
Kris K
Thanks for all,
KJK99, could you tejj me what's the references of your D.A.C. ?
cbs350-24t-4g-in and  cbs350-8t-in works fine with  sfp MGBLX1 in both switch . I want to connect another cbs350-24t switch to existing cbs350-8t with MGBLX1 but port up,
