12-15-2023 11:49 PM
Hello everyone, my customer recently purchased a CBS250 device, and requested to display DRAM information. I tried show version but it doesn't show any information about DRAM, Are there any commands support this?
Solved! Go to Solution.
12-16-2023 04:09 AM
@quang-nv if you have a chance to do a reboot, check the console output. but if you need more granular details i suggest to get cisco support like @balaji.bandi mentioned.
12-16-2023 01:17 AM - edited 12-16-2023 01:18 AM
@quang-nv hi, i am ot 100% sure about this model, after checking few online captures, DRAM capacity displayed on console output, when system is booting.
also according to datasheet this model have 512MB DRAM.
also try
'show tech-support' to see if you getting any output related to DRAM.
12-16-2023 01:29 AM
Hi, Kasun Bandara
I also tried 'show tech-support' but it seems that is not the DRAM information stated on the datasheet (512MB)
12-16-2023 04:09 AM
12-16-2023 01:55 AM
I believe you get only limited information on the small business switches, that is limitation. (unlike enterprise switch can show all the information).
may be if the customer insisting ( contact SMB TAC can help you ).
