Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2873 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4429 Views
  • 1 replies
  • 16 Helpful votes
I have Cisco SG300-28, SG350-28, and Catalyst 2960 switches. SG350-28 and Catalyst 2960 are connected to SG300-28 via a trunk. The Bridge Priority of Cisco SG300-28 is set as 4096. However, the Catalyst 2960 switch sees it as root bridge only for VLA...
sakar by Level 1
  • 2221 Views
  • 4 replies
I'm currently trying to configure the above switch at home for testing/lab purposes and am stuck at the moment. Can someone please tell me how to delete both VLAN 100's from my switch? I did a little research and found that there's a vlan.dat file on...
Mork1978 by Level 1
  • 510 Views
  • 1 replies
Resolved! SG350X-48P updates
Hi. We've got a stack of 4 SG350X-48P switches running an  old 2.5.0.83 code. I'd like to update them and looks like 2.5.9.16 is the latest. Can I move directly from this old version to the new version - or are there incremental updates I need to per...
Hi,I am configuring CBS-350 24 Port switch that needs to be added in the production environment. Currently, the GVRP is disabled on this switch.I need to know while the GVRP is disabled, can I connect that switch with core switch 4500. I mean CBS swi...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
