11-23-2023 02:33 AM - edited 11-23-2023 02:34 AM
Hello everyone,
i have a sg300-28 Switch and want to restore the config on an other sg300-28PP Switch?
Is that possible? And are there fw ver requirements?
thx in advance
Solved! Go to Solution.
11-23-2023 04:12 AM
They are different models. rather restoring config,
pickup the configuration from command level show run and apply the config on the new device - for easy and it any errors or command not accepted that should let you know as error.
11-23-2023 04:12 AM
11-25-2023 03:56 PM
It works. I restored the config from my SG300-28 on the SG300-28PP without problems. Afterthat i adjusted the poe config. All is working fine.
11-26-2023 02:47 AM
Glad that all good and you able to resolve the issue - we mark as resolved.
