03-01-2020 12:58 PM
In my lab, I have 2 Cisco SG350-10 switches connected to a Palo Alto 220 firewall. On my switches, I want to do layer 2 switching and routing on the firewall. Here is my setup:
SG350-10 switch #1
ports 1-3 VLAN2 set as access ports
ports 4-6 VLAN4 set as access ports
ports 7-8 VLAN5 set as access ports
port 9 set as trunk port connected to Palo Alto (tagging all VLAN's except VLAN1)
port 10 set as trunk port connected to Switch #2 (tagging all VLAN's except VLAN1)
SG350-10 switch #2
port 9 set as trunk port - not used
port 10 set as trunk port connected to Switch #1 (tagging all VLAN's except VLAN1)
VLAN1 192.168.0.1/16
VLAN2 10.0.2.0/24 (Gateway .1)
VLAN4 10.0.4.0/24 (Gateway .1)
VLAN5 10.0.5.0/24 (Gateway .1)
In VLAN management>VLAN settings, I have the VLAN's created
In IP Configuration>IPv4 Interface I have the VLAN Interfaces created with the appropriate IP addresses and subnet masks.
PC #1 10.0.2.5/24
PC #2 10.0.4.5/24
PC #3 10.0.5.5/24
I have the interfaces set up in the Palo Alto
I can connect each PC in the appropriate VLAN and ping the other by IP address. Even VLAN's between switches. The only thing I can't ping is the gateway (.1) on the firewall from any VLAN. Do I need to set up an IPv4 route to the firewall?
I am wondering if I am missing something in my switch setup. Any help would be appreciated since I am fairly new to this?
Solved! Go to Solution.
04-07-2020 08:47 AM
After talking with Palo Alto, The issue was with the config on my firewall. It seems my switches were set up just fine.
03-30-2020 09:15 AM
Please configure the management IP on the switches from the same IP pool as configured in Firewall, add default route on the switches towards firewall LAN IP, allow all the VLANs on the Trunk port (VLAN 1 as native will be helpful). All the VLAN interfaces will be configured on the Firewall, PC gateway will be the respective VLAN interface IP.
04-07-2020 08:47 AM
12-28-2022 10:45 AM
What is the issue on your firewall?
