need help selecting a switch
nflnetwork
hello, we require a 1 GB switch with minimum 6 SFP and 8 Gigabit ethernet
I was looking at the Small Business 350 series but could not find anything?
I need to connect single mode fiber using LC connector.
I also need to connect my firewall using 1 GB Ethernet.
Do we have recomendation on somethign that will work?
9 Replies 9
balaji.bandi
There is some model before 550 SMB switch (but end of life)
https://www.cisco.com/c/en/us/products/switches/550x-series-stackable-managed-switches/index.html
For that range, you can look Meraki switch
https://meraki.cisco.com/product/switches/stackable-access-switches/ms390-48/
In long run, I would look Cat 9K switches.
you can compare models:
https://www.cisco.com/c/en/us/products/switches/switch-selector.html?ccid=cc000098&oid=otres000315
BB
48 port is too much
what about
CBS350-24S-4G-NA
Thoughts?
Those models did not get the 6 SFP that you looking....also they coming end of life soon I guess.
if you have 4 SFP, then you have a choice more, only higher models have 6 SFP ports
look at Meraki, they have also gotten a dashboard from the cloud to manage devices.
BB
You may check the model CBS350-16XTS if that fits your requirements.
More details for that CBS350-16XTS switch model are available on the data sheet https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html
Are SFP+ ports backward compatible with 1G SFP optics?
As per the CBS350 series switch admin guide, the SFP+ ports are compatible with the Cisco SFP 1G optical modules MGBSX1, MGBLX1, MGBLH1 and MGBT1.
You may refer the admin guide link https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/Administration-Guide/cbs-350.pdf
Page - 11 (13 of 424)
jimstewart77
To get 6 SFP you need to move to the 10GB switches.  You can use these with SFPs or SPF+s
CBS350-16XTS would be the smallest (8 copper, 8 SFP+).  24XTS next up (12/12)
nflnetwork
it turns out we only require 3 SFP.  the other connections can be copper. so, any switch with 4 SFP uplink module should do the trick .i was looking at the Meraki MS120-24P.  (Especially since lead times on ordering is like 1 days.)
Meraki is good option for this
