Problem with DHCP
mmalaoui
I created 4 VLANS in my switych cisco SF300-48PP
the switch is connected to a 192.168.1.1 ADSL router
VLAN 1 address 192.168.1.6 DHCP 192.168.1.7-192.168.1.63 / MASK 255.255.225.192
VLAN 2 address 192.168.1.65 DHCP 192.168.1.66-192.168.1.128 / MASK 255.255.225.192
VLAN 3 address 192.168.1.130 DHCP 192.168.1.7-192.168.1.190 / MASK 255.255.225.192
VLAN 1 address 192.168.1.192 DHCP 192.168.1.193-192.168.1.250 / MASK 255.255.225.192
My problem what I have the internet only in the VLAN1 not in the others
Cordially
35 Replies 35
So you confirmed all working as expected ? i did not get last post - is this measn your issue is solved ?
BB
Hello good day,
sorry for my English.
I have SG350X-24, and I also have Vlan 1 with internet connection, but the other vlan 2,3,10, (etc)
they do not have internet connection ..
I'm following the thread because I have the same problem.
Thank you
can you share switch routing details and switch running mode (l2 or l3)?
Good luck
KB
this is the configuration that I followed
My IP router 172.22.0.1
and that of the IP switch 172.22.0.2
Switch-Cisco-01#configure terminal
Switch-Cisco-01(config)#interface vlan 1
Switch-Cisco-01(config-if)#ip address 172.28.0.1 255.255.0.0
Switch-Cisco-01(config-if)#no shutdown
Switch-Cisco-01(config-if)#exit
Switch-Cisco-01(config)#interface vlan 10
13-Dec-2018 20:52:42 %LINK-I-Up: Vlan 10
Switch-Cisco-01(config-if)#ip address 172.19.0.1 255.255.0.0
Switch-Cisco-01(config)#interface vlan 20
13-Dec-2018 20:53:25 %LINK-I-Up: Vlan 20
Switch-Cisco-01(config-if)#ip address 172.20.0.1 255.255.0.0
Switch-Cisco-01(config)#interface vlan 30
13-Dec-2018 20:54:09 %LINK-I-Up: Vlan 30
Switch-Cisco-01(config-if)#ip address 172.30.0.1 255.255.0.0
Switch-Cisco-01(config)#13-Dec-2018 20:55:06 %AAA-I-CONNECT: New http connection for user cisco, source 172.28.0.10 destination 172.28.0.1 ACCEPTED
13-Dec-2018 20:56:53 %LINK-W-Down: te1/0/2
13-Dec-2018 20:57:00 %LINK-I-Up: te1/0/2
13-Dec-2018 20:57:04 %STP-W-PORTSTATUS: te1/0/2: STP status Forwarding
Switch-Cisco-01(config)#interface te1/0/2
Switch-Cisco-01(config-if)#no switchport
Switch-Cisco-01(config-if)#ip address 172.22.0.2 255.255.0.0
Switch-Cisco-01(config)#ip route 0.0.0.0 0.0.0.0 172.22.0.1
Switch-Cisco-01(config)#end
Switch-Cisco-01#copy running-config startup-config
Overwrite file [startup-config].... (Y/N)[N] ?Y
13-Dec-2018 21:02:38 %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://system/configuration/startup-config
13-Dec-2018 21:02:40 %COPY-N-TRAP: The copy operation was completed successfully
Copy succeeded
Switch-Cisco-01#
what is the switch mode configured? also have you added incoming routed from your router to inside switch?
Good luck
KB
Problem solved, it was necessary to put back the mask of the Modem ADSL with 255.255.255.0 thanks for everyone cordially
