03-02-2022 07:48 AM
Hello Community,
I'm writing to let you know that there is a critical POE defect in the CBS350 switches and you should avoid them if you require stable POE operations. This apparent software defect causes POE ports to randomly fault after 8 to 12 hours and the powered device will go offline. Cisco does not have a resolution, workaround, or timeline to address this situation.
Please help Cisco prioritize this issue by opening a TAC case if you are experiencing this issue. Additionally, please escalate this for additional visibility through your sales channels.
All the best!
Solved! Go to Solution.
03-03-2022 02:05 PM
You have an 8-port PoE switch on which PoE is disabled on all PoE ports and to which no PDs have ever been connected on any port at any point during its current uptime, and all ports just randomly faulted? Are the ports faulted because you've manually set the power limit to 0W, as some ostensible attempt at hardening them?
The timestamps of your posts in the other thread reveal that you changed power limit mode and disabled inrush test prior to opening your TAC case.
Post the startup-config for that switch, cycle it, and then re-post that output.
03-03-2022 02:35 PM - edited 03-03-2022 02:39 PM
@cyberconsultants wrote:You have an 8-port PoE switch on which PoE is disabled on all PoE ports and to which no PDs have ever been connected on any port at any point during its current uptime, and all ports just randomly faulted?
Yes, that is correct.
@cyberconsultants wrote:Are the ports faulted because you've manually set the power limit to 0W, as some ostensible attempt at hardening them?
No, the ports fault regardless of the power limit or even if it is cleared. Your postulate that I am trying to harden the switch is grossly incorrect. Even with the default POE settings, the strange and erratic behavior takes place.
SW-3#show clock 22:33:07 UTC Mar 3 2022 Time from SNTP is enabled Operational Time Source: SNTP (last synchronized 00:13:51 ago) Time from Browser is disabled SW-3#show power inline Power-limit mode: Port based Usage threshold: 95% Trap: Disable Legacy Mode: Enable Inrush Test: Disable Guard-Band Value: Static (2W) Unit Module Nominal Consumed Temp SW PSE chipset Power (W) Power (W) (C) Version HW Revision ---- -------------- --------- ------------ -------- ------------- ----------------- 1 CBS350-8P-E-2G 60 0 (0%) 47 0.2.0.17 TPS2388 - 0x40C4 Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi1 Never Fault 0.0 - low gi2 Never Fault 0.0 - low gi3 Never Fault 0.0 - low gi4 Never Fault 0.0 - low gi5 Never Fault 0.0 - low gi6 Never Fault 0.0 - low gi7 Never Fault 0.0 - low gi8 Never Fault 0.0 - low SW-3#configure SW-3(config)#interface range Gi1-8 SW-3(config-if-range)#power inline auto SW-3(config-if-range)#power inline never SW-3(config-if-range)#end SW-3#show power inline Power-limit mode: Port based Usage threshold: 95% Trap: Disable Legacy Mode: Enable Inrush Test: Disable Guard-Band Value: Static (2W) Unit Module Nominal Consumed Temp SW PSE chipset Power (W) Power (W) (C) Version HW Revision ---- -------------- --------- ------------ -------- ------------- ----------------- 1 CBS350-8P-E-2G 60 0 (0%) 47 0.2.0.17 TPS2388 - 0x40C4 Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi1 Never Off 0.0 - low gi2 Never Off 0.0 - low gi3 Never Off 0.0 - low gi4 Never Off 0.0 - low gi5 Never Off 0.0 - low gi6 Never Off 0.0 - low gi7 Never Off 0.0 - low gi8 Never Off 0.0 - low SW-3#show power inline GigabitEthernet 1 Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi1 Never Off 0.0 - low Port Status: Port is off. User setting Port standard: 802.3AT Admin power limit: 0.0 watts Time range: Max Power Allocation: 0.0 watts Spare pair: Disabled Negotiated power: 0.0 watts (None) Current (mA): 0 Voltage(V): 0.0 Overload Counter: 68 Short Counter: 6 Denied Counter: 0 Absent Counter: 0 Invalid Signature Counter: 0
SW-3#show clock 22:34:07 UTC Mar 3 2022 Time from SNTP is enabled Operational Time Source: SNTP (last synchronized 00:14:51 ago) Time from Browser is disabled SW-3#
03-03-2022 03:54 PM
Hardening, manual power budgeting—you're right, the reason any port would have its power limit manually set at 0W (and which already has its PoE mode administratively disabled) is beyond unclear and I'm speculating.
Set limit mode to class, or at least set all individual port power limits back to default, re-enable inrush test, commit/copy to su, post su config, cycle the switch (not just PoE mode on all PoE ports), and then re-post show power inline and a show power inline [interface]. If you can show a random fault at that point, preferably in continuous output like you've done above, then other configuration settings aside from limit mode and/or port power limit or, I suppose, software bugs might be considered.
You originally describe the issue as:
Are we talking faults with PDs connected, or faults completely at random? If completely at random, then take the steps above. Or try a factory reset for that matter. Faults with PDs connected versus completely random faults are obviously entirely different troubleshoots.
03-04-2022 06:27 AM
@cyberconsultants wrote:or, I suppose, software bugs might be considered.
Thanks so much @cyberconsultants, for your efforts to bring a notion of doubt to this situation under the guise of assistance. Nonetheless, I hope the below output provides proof beyond a reasonable doubt that the aforementioned erratic behavior exists. I'm using the power inline never command on the individual ports is for two reasons: (1) to workaround known issue CSCvu81814 and (2) the default admin power limit is 30W which oversubscribes the switch's POE capability.
@cyberconsultants wrote:Are we talking faults with PDs connected, or faults completely at random?
Both, see below.
SW-3#show clock | include UTC 13:59:54 UTC Mar 4 2022
SW-3#show system | include Up System Up Time (days,hour:min:sec): 00,09:02:54
SW-3#show power inline Power-limit mode: Class based Usage threshold: 95% Trap: Disable Legacy Mode: Enable Inrush Test: Enable Guard-Band Value: Static (2W) Unit Module Nominal Consumed Temp SW PSE chipset Power (W) Power (W) (C) Version HW Revision ---- -------------- --------- ------------ -------- ------------- ----------------- 1 CBS350-8P-E-2G 60 0 (0%) 46 0.2.0.17 TPS2388 - 0x40C4 Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi1 Never Off 0.0 - low gi2 Auto Searching 0.0 - low gi3 Never Off 0.0 - low gi4 Never Off 0.0 - low gi5 Never Off 0.0 - low gi6 Never Fault 0.0 - low gi7 Never Off 0.0 - low gi8 Never Fault 0.0 - low
SW-3#show power inline GigabitEthernet 6 Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi6 Never Fault 0.0 - low Port Status: Port is off. Overload state Port standard: 802.3AT Admin power limit (for port power-limit mode): 30.0 watts Time range: Max Power Allocation: 30.0 watts Spare pair: Disabled Negotiated power: 0.0 watts (None) Current (mA): 0 Voltage(V): 0.0 Overload Counter: 24 Short Counter: 1 Denied Counter: 0 Absent Counter: 2 Invalid Signature Counter: 0
SW-3#show interfaces status GigabitEthernet 6 Flow Link Back Mdix Port Type Duplex Speed Neg ctrl State Pressure Mode -------- ------------ ------ ----- -------- ---- ----------- -------- ------- gi6 1G-Copper -- -- -- -- Down -- --
SW-3#show power inline GigabitEthernet 8 Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi8 Never Fault 0.0 - low Port Status: Port is off. Overload state Port standard: 802.3AT Admin power limit (for port power-limit mode): 30.0 watts Time range: Max Power Allocation: 30.0 watts Spare pair: Disabled Negotiated power: 0.0 watts (None) Current (mA): 0 Voltage(V): 0.0 Overload Counter: 35 Short Counter: 0 Denied Counter: 0 Absent Counter: 4 Invalid Signature Counter: 0
SW-3#show interfaces status GigabitEthernet 8 Flow Link Back Mdix Port Type Duplex Speed Neg ctrl State Pressure Mode -------- ------------ ------ ----- -------- ---- ----------- -------- ------- gi8 1G-Copper -- -- -- -- Down -- --
SW-3#show startup-config | exclude ^username config-file-header SW-3 v3.1.1.7 / RCBS3.1_930_871_081 CLI v1.0 file SSD indicator encrypted @ ssd-control-start ssd config ssd file passphrase control unrestricted no ssd file integrity control ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0 ! ! unit-type-control-start unit-type unit 1 network gi uplink none unit-type-control-end ! spanning-tree priority 8192 port jumbo-frame vlan database vlan 1010,1013-1014 exit voice vlan oui-table add 0001e3 Siemens_AG_phone voice vlan oui-table add 00036b Cisco_phone voice vlan oui-table add 00096e Avaya voice vlan oui-table add 000fe2 H3C_Aolynk voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone voice vlan oui-table add 00e075 Polycom/Veritel_phone voice vlan oui-table add 00e0bb 3Com_phone no eee enable hostname SW-3 no logging console passwords aging 0 ip ssh server snmp-server location Family snmp-server contact noc@quindar7.net no ip http server sntp server 10.0.10.1 poll no sntp server pool.ntp.org no sntp server time-a.timefreq.bldrdoc.gov no sntp server time-b.timefreq.bldrdoc.gov no sntp server time-c.timefreq.bldrdoc.gov no sntp server time-pnp.cisco.com ! interface vlan 1 name Default no ip address dhcp shutdown ! interface vlan 1010 name Management ip address 10.0.10.13 255.255.255.128 ! interface vlan 1013 name IoT ! interface vlan 1014 name Media ! interface GigabitEthernet1 description UPS-3 switchport access vlan 1010 switchport trunk native vlan none switchport trunk allowed vlan none power inline never ! interface GigabitEthernet2 description IOT-ZWAVE switchport access vlan 1013 switchport trunk native vlan none switchport trunk allowed vlan none ! interface GigabitEthernet3 speed 10 no negotiation description IOT-POOL switchport access vlan 1013 switchport trunk native vlan none switchport trunk allowed vlan none power inline never ! interface GigabitEthernet4 description IOT-HVAC switchport access vlan 1013 switchport trunk native vlan none switchport trunk allowed vlan none power inline never ! interface GigabitEthernet5 description SND-FAMILY switchport access vlan 1014 switchport trunk native vlan none switchport trunk allowed vlan none power inline never ! interface GigabitEthernet6 description BLU-FAMILY switchport access vlan 1014 switchport trunk native vlan none switchport trunk allowed vlan none power inline never ! interface GigabitEthernet7 description ATV-FAMILY switchport access vlan 1014 switchport trunk native vlan none switchport trunk allowed vlan none power inline never ! interface GigabitEthernet8 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none power inline never ! interface GigabitEthernet9 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface GigabitEthernet10 description SW-1.Gi14 ip dhcp snooping trust switchport mode trunk switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan 1010,1013-1014 ! interface Port-Channel1 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface Port-Channel2 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface Port-Channel3 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface Port-Channel4 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface Port-Channel5 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface Port-Channel6 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface Port-Channel7 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! interface Port-Channel8 shutdown description [UNUSED] switchport access vlan none switchport trunk native vlan none switchport trunk allowed vlan none ! exit ip dhcp snooping ip dhcp snooping vlan 1010 ip dhcp snooping vlan 1013 ip dhcp snooping vlan 1014 ip default-gateway 10.0.10.1
03-04-2022 06:47 AM
For posterity: the only PoE issue ("defect"?) OP seems to have presented is with Ubiquiti PDs.
03-04-2022 07:53 PM
@cyberconsultants wrote:For posterity: the only PoE issue ("defect"?) OP seems to have presented is with Ubiquiti PDs.
This is not true. I have also presented a case where a PoE port with no device connected at all goes into the Port is off. Overload state status.
03-03-2022 03:56 PM
Hello d0nni3q84,
Thank you for raising this issue. I've not experienced the described issue with the PoE enabled CBS350 running in my home network. I've shared your post with the team and they are in turn sharing it internally to increase awareness while we investigate further. We'll provide more details or a workaround should they become available.
If anyone else is impacted, please open a case with TAC. It does help raise awareness on issues.
03-03-2022 05:23 PM
Hello @CoreyP319,
Please share the exact switch model and firmware version that you have running in your home network where you do not observe this behavior.
Thank you!
03-04-2022 02:57 AM
I have seen ports on mine that have PoE live but a non-PD device (computer) connected show PoE fault. The port however continues to work perfectly and the port itself isn't in fault, just the PoE.
Ports with PoE disabled and plugged into a non-PD device show PoE disabled.
I didn't give much thought to that fault state as it just seems to be a reporting oddity.
03-04-2022 04:25 AM
Same behavior here. Since the last firmware our Lancom devices are working, before there was definitely a problem with PoE.
03-04-2022 06:06 AM
@jimstewart77 wrote:I have seen ports on mine that have PoE live but a non-PD device (computer) connected show PoE fault. The port however continues to work perfectly and the port itself isn't in fault, just the PoE.
Yes, that's a known issue and benign, where the status is Port is off. Short condition and the Short Counter continuously increments. I'm not worried about the scenario, since as you said, the port sill operates.
03-21-2022 08:19 PM
During beta testing with Cisco TAC, I can confirm this issue is resolved in Software version 3.1.1.10 and MCU version 0xF0. Unfortunately, I do not have a release timeline available; however, I encourage you to reach out to Cisco TAC if you are experiencing this issue.
05-01-2022 10:07 AM
I am using a CBS350-8P-E-2G. At the moment just one POE device is connected. It's an Aruba AP22 Access Point.
I am also facing the Overload issue:
Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi1 Never Fault 0.0 0 low Port Status: Port is off. Overload state Port standard: 802.3AT Admin power limit: 30.0 watts Time range: Max Power Allocation: 30.0 watts Spare pair: Disabled Negotiated power: 0.0 watts (None) Current (mA): 0 Voltage(V): 0.0 Overload Counter: 6 Short Counter: 0 Denied Counter: 1 Absent Counter: 0 Invalid Signature Counter: 0
The statistic looks like this:
Is the denied counter also part of the known issue?
Michael
05-02-2022 10:50 PM
I personally did not observe the Denied counter incrementing; however, it does mean that the switch did not provide power to the port since the requested power exceeded a limit. What is the output of the following commands?
show run interface GigabitEthernet 8
05-04-2022 01:11 AM
Thanks for your reply. The output looks like this:
AzCiscoSwitch#show power inline GigabitEthernet 8
Interface Admin Oper Power (W) Class Device Priority ---------- ---------- ----------- ----------------- ----- -------------- -------- gi8 Auto On 5.641 (16.5) 3 high Port Status: Port is on. Valid resistor detected Port standard: 802.3AT Admin power limit: 30.0 watts Time range: Link partner standard: 802.3AF Max Power Allocation: 30.0 watts Spare pair: Disabled Negotiated power: 16.500 watts (LLDP) Current (mA): 107 Voltage(V): 53.0 Overload Counter: 17 Short Counter: 0 Denied Counter: 268 Absent Counter: 12 Invalid Signature Counter: 0
AzCiscoSwitch#show run interface GigabitEthernet 8 interface GigabitEthernet8 description GzAccessPoint switchport mode trunk switchport access vlan 10 power inline priority high !
Michael
