"default interface" equivalent for SG300/500 switches?
rcoote5902_2
Level 2
Level 2
Can anyone tell me if there is an equivalent CLI command to reset an interface configuration to default?
In IOS it is "default interface <interface>" which removes all configuration from that switch port. I don't seem to be able to find the same in the SG series CLI.
Rob
10 Replies 10
chrebert
Level 4
Level 4
Hello Rob,
There isn't an equivalent command on the SG series switches, but I will be bringing it up as a feature request, because it would be quite useful.
Until then the only way to reset a port would be to use all of the no versions of the commands, which I know can be a bit of a pain.
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
hello please had you luck with that feature request? was it accepted by management? We are missing such feature on SG switches as well. thanks!
We'll check with the switch product team.
Thanks.
Yiu Kay Lee
Concentrix at Cisco
.:|:.:|:. CISCO | Yiu Kay Lee | Network Engineer | SMB Presales | yiulee@cisco.com
I have this difficulty in performing the same procedure.
Default ports
Does cisco have any feedback on this topic?
CISCO SERIE GS300
DON'T HAVE -> (DEFAULT) INTERFACE GEXX
att,
JODSON MARTINS
any news?
hard to believe that default is missing
BR
Was informed that default interface CLI command feature is not in the road-map.
Thanks.
Yiu Kay Lee
Concentrix at Cisco
Here we are 3 years later. Can we get it on the roadmap? The No commands unfortunately don't clear all the garbage automatically created.
Please add this command !
When to expect this feature? :(
rajp
use this command : no macro auto smartport
