SG300-28 switch in boot loop after firmware upgrade
desrig595
After performing a firmware upgrade on an SG300-20 switch from ver 1.1.0.73  to 1.2.5.70 the switch now boots up with the following error and resets:
30-Aug-2011 10:47:33 %L1Mngr-F-PARAMTOOLONG: csco-sb parameter %s is too long.
The attached file contains a full output of the console boot process.
I have tried loading different versions from the console, but all produce the same error.
Has any one any idea how to resolve this issue?
Des
8 Replies 8
bhackbarth
There have been some reports lately that certain browsers may cause issues when upgrading, namely Chrome and Firefox. I used firefox to update my 28P switches and got some strange results, such as ports missing PoE. Removing and restoring power / resetting with the button cleared all the issues up. What browser did you use? To recover the switch the first thing I would try is to use a paper clip and hold the reset button for around 30 seconds. If you haven't done so, remove and restore AC power. Several issues I had would ONLY clear after doing that.
Brayton, thanks for the good information and reply.
In addition to those steps, if this does not resolve, you may have to load the firmware via Hyperterminal using XMODEM if the switch continues to reboot loop.
The entire process will take about 20-25 minutes.
1) To load the firmware via Hyperterminal;
Bits per seconds: 115200
Databits: 8
Partiy: None
Stop bits:1
Flow control: None
2) Reboot the switch, just unplug the power and plug it back in
3) When prompted, press ESC
4)The startup menu will appear, choose option 1 -> Download software
5) On the top of the Hyperterminal, choose the option TRANSFER -> Send File
6) Browse the firmware file and select it
7) Choose protocol->  Xmodem
8) Click send
This process will take 20 minutes or so, give or take, just let the switch idle until the process is done.  This should resolve the reboot loop.  If the reboot loop persists, try to load the 1.1.2.0 firmware instead then perform your upgrade. It should be stable.
If you need assistance with this process, please call 1.866.606.1866 and have your CCOID, product serial number and supply this forum post to the agent.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
I have tried to load the firmware via the serial port before, trying again with 1.1.2.0 firmware give the following output:
*****************  SYSTEM RESET  *****************
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.0.4 Built  08-Apr-2010  16:37:57
Networking device with Marvell ARM CPU core. 128 MByte SDRAM.
I-Cache 16 KB. D-Cache 16 KB. L2 Cache 256 KB. Cache Enabled.
MAC Address   :  20:20:20:89:20:10.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
Board ID is 9
Device ID 0xdff411ab
*** Running  SW  Ver. 1.1.2.0  Date  12-Nov-2011  Time  23:34:26 ***
HW version is V
Base Mac address is: 20:20:20:89:20:10
Dram size is  : 128M bytes
Dram first block size is  : 98304K bytes
Dram first PTR is  : 0x1C00000
Dram second block size is  : 4096K bytes
Dram second PTR is  : 0x7C00000
Flash size is: 16M
12-Nov-2011 23:34:28 %CDB-I-LOADCONFIG: Loading running configuration.
12-Nov-2011 23:34:28 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SG 300-28
Device 0: GT_98DX3025 (AlleyCat)
-- Unit Standalone                --
12-Nov-2011 23:34:45 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration .
Tapi Version: v1.9.5
Core Version: v1.9.5
12-Nov-2011 23:35:26 %L1Mngr-F-PARAMTOOLONG: csco-sb parameter %s is too long.
***** FATAL ERROR *****
Reporting Task: ROOT.
Software Version: 1.1.2.0 (date  12-Nov-2011 time  23:34:26)
0x169bbc
0x166760
0x696a80
0x475f3c
0x47b408
0x47b5c4
0x7e7140
0x7e85d4
0x7e9924
0x1cff30
0x1c9d84
0x121d84
Hi Des, if the switch is not recovering writing the firmware directly to the flash via xmodem, we should open up a service request.
Here is a list of the SBSC support numbers;
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Give a call any time and please have your CCOID, serial number and provide this community forum link.
Des, please continue to use the 1.1.2.0 firmware. The business unit has recalled the 1.2.5.70 firmware. If the switch continues to reboot loop while loading the 1.1.2.0 firmware, the SBSC support will be happy to assist in trying to recover the switch.
Please reference the following;
https://supportforums.cisco.com/docs/DOC-25157
nicolas.korten
Hello Des Riglar, hello Support community,
Thank you for your post. Could you solve the Problem? I`m having the same issue with a SF 302-08MP switch, i have tried the 3 firmwares offered on the cisco website, and no one will boot. I think there is a part of the flash that does not get overwritten by the firmware upgrade and produces the error, maybe in the snmp server.
It reboots with this error:
28-Apr-2010 13:34:14 %L1Mngr-F-PARAMTOOLONG: csco-sb parameter %s is too long.
I have the full logfile attached with the third firmware I have tried, version 1.0.0.27, but none of the firmwares solve the problem.
Hope to Rescue the Switch,
Nico
Here is how to recover the switch-
https://supportforums.cisco.com/docs/DOC-27000
-Tom
nicolas.korten
Hello Tom, Thanks for your reply,
I had done the process before with the 3 firmwares offered in the cisco website. I did it again, and i get a boot loop again, with following error:
%L1Mngr-F-PARAMTOOLONG: csco-sb parameter serialNo is too long.
Any ideas?
Thank you,
Nico
Console
     Startup Menu
[1]  Download Software
[2]  Erase Flash File
[3]  Password Recovery Procedure
[4]  Set Terminal Baud-Rate
[5]  Stack menu
[6]  Back
Enter your choice or press 'ESC' to exit:
Downloading code using XMODEM.
-- Download complete --
Calculating file's checksum...OK
Erasing FLASH ->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Writing to flash 0x6aa500 records...
Setting checksum: 0x350925f6 , Address: 0x0
OK.
Flash programming success.
Perform WARM BOOT ...
MAC Address   :  58:35:d9:96:7f:5d.
100%
100%
OK
Running from RAM...
Board ID is 22
Device ID 0xdf5111ab
*** Running  SW  Ver. 1.2.7.76  Date  19-Jul-2012  Time  17:54:43 ***
HW version is V
Base Mac address is: 58:35:d9:96:7f:5d
Dram first block size is  : 101376K bytes
Dram first PTR is  : 0x1900000
Flash size is: 16M
19-Jul-2012 17:54:46 %CDB-I-LOADCONFIG: Loading running configuration.
19-Jul-2012 17:54:47 %CDB-I-LOADCONFIG: Loading startup configuration.
Slot 1 - SF302-08MP
Device 0: GT_98DX1005 (AlleyCat)
19-Jul-2012 17:55:02 %L1Mngr-F-PARAMTOOLONG: csco-sb parameter serialNo is too l
ong.
Software Version: 1.2.7.76 (date  19-Jul-2012 time  17:54:43)
***** DEBUG *****
DEBUG LOG IS EMPTY
0x16a614
0x167054
0x6bdc18
0x490518
0x4959e4
0x495bac
0x815674
0x816b10
0x817e64
0x1d51e8
0x1cb010
0x121d3c
