SG550XG - Airflow
MaDe
Good day,
I searching for official documentation/diagramm how the airflow is working in the SG550XG models.
Thx,
MaDe
Hi MaDe,
The airflow path is from left to right. Do not wall-mount the switch with its front panel facing up. Following safety regulations, wall mount the switch with its front panel facing down or to the side to prevent airflow restriction and to provide easier access to the cables.
5 Replies 5
balaji.bandi
Most of the cisco switches  (other than nexus and chasis) as i know front to rear.
BB
MaDe
thanks for your reply. the SG models have their fans on the side. I would like to know if there is also an intake and outtake.
Hi MaDe,
thanks for the info. Is there a diagram or a sheet you can share for me?
Thx,
MaDe
Martin Aleksandrov
There is no such official documentation we could provide at this point.
