Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by • Cisco Employee
  • 18587 Views
  • 36 replies
  • 2 Helpful votes
Hi all,I have in my hand an sg300-28p with firmware 1.3.0.62 and bootloader 1.1.0.6. I want to put it in the latest version (I'm aware of the in-between I have to do because of new bootloader version) but I don't see any firmware for my switch.There ...
elwan by • Community Member
  • 19028 Views
  • 11 replies
We have 6 SG350-52P's the No. 3 quit. When taking it out of the rack heard things rattling around inside.  Opened up the case the inside top of the cover burnt and the all the boards behind the rj45 connections puffed.  I have seen a lot of equipment...
btentinger by • Community Member
  • 183 Views
  • 2 replies
Good afternoon,   Having an issue with VTP propagation.  I have two 2950 switches, Switch_1 as VTP server and Switch_2 as VTP Client and both fa0/23 ports are configured as trunks.  Switch_1 has four Vlans (vlan 1, vlan 10, vlan 20, vlan 30) but they...
paquinjrm by • Community Member
  • 1201 Views
  • 3 replies
I have a C9500-48Y4C IOS XE 17.12.4 that is notifying of a lot of MAC flapping. This is the typical error log. Oct 27 13:14:41.253: %SW_MATM-4-MACFLAP_NOTIF: Host 0050.56b1.96a0 in vlan 412 is flapping between port Twe1/0/3 and port Po1When the switc...
rlwilson by • Visitor
  • 3714 Views
  • 7 replies
Good day pros,Two week a go, was trying to upgrade  Cisco C9200 (STACK2) switch from IOS cat9k_lite_iosxe.17.12.06.SPA.bin to cat9k_lite_iosxe.17.12.08.SPA.bin. It was successfully uploaded and I changed the boot variable. (As I did upgraded many sta...
Is there a way to check basic Meraki switch hardware health metrics? Unit temperature, fan speeds, any internal failures?The "device health" tab seems to only expose some hardware statuses (CPU: good / poor; memory: good / poor, etc.) - but I see no ...
kindzma by • Level 4
  • 676 Views
  • 7 replies
  • 1 Helpful votes
Hi all,Yesterday I upgraded two Cisco 9500-40X switches from IOS-XE 16.6.9 to 17.18.4 and configured them in a StackWise Virtual setup.In my previous experience with the Cisco C9500-48Y4C-A, the standby switch's console port became unavailable for co...
marzi by • Level 4
  • 303 Views
  • 3 replies
Hello, our 9200 switches with code 17.9.4a receives dacl from ise and authorize clients successfully. Based on the complaints (endpoint can access to destinations that they shouldn’t as destinations not allowed in DACL) we started to see if anything ...
tungrwaga58 by • Community Member
  • 1305 Views
  • 6 replies
