3560 SPAN Port Problem
cfujimura
I am testing a record software for  Cisco IP Phones. This software  must receive voice traffic from  mirrorred ports on a 3560 switch. I´ve  configured the span ports in  this switch, but the only traffic I can see  is broadcast and multicast.  I didn´t see neither the audio streamming  nor the call signaling (I  can´t see any unicast traffic). Below is part  of the configuration of  the 3560 switch.
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast bpduguard default
spanning-tree etherchannel guard misconfig
spanning-tree uplinkfast
spanning-tree backbonefast
vlan internal allocation policy ascending
interface FastEthernet0/1
  switchport access vlan 23
  switchport mode access
  switchport voice vlan 51
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/14
interface FastEthernet0/48
  speed 100
  duplex full
monitor session 1 source interface Fa0/1 - 6 , Fa0/14
monitor session 1 filter vlan 51
monitor session 1 destination interface Fa0/48
The ports with IP Phones are 1 to 6 and 14. The port that will receive the VoIP traffic is 48.
The switch is loaded with  C3560 Software (C3560-IPBASE-M), Version 12.2(50)SE1.
Have anyone had this problem before?
Best Regards.
Fujimura.
17 Replies 17
letsgomets
Have you tried removing the filter and see if you get any data?
I´ve tried already without the filter. The difference is that, without the filter, I see the broadcast and multicast from vlan 23 (vlan 23 is the pc vlan; the PCs are connect to the IP Phones; vlan 51 is the voice vlan). I´ve tried too the source as vlan 51 instead of the range of ports. But the result is the same with and without the filter.
Best Regards.
Fujimura.
It seems your configuration is not actually being applied. Try removing the session configuration and use a different session number of 2 or some other integer. If it still doesn't work you could be running into a software or hardware problem.
Another idea, just try a one to one session and see if you get data that way. Perhaps your control plane cannot process the number of source ports you are configuring.
I´ve tried another session (session id 2) with 1 to 1 port, but it didn´t work. I still is receiving only broadcast and multicast traffic.
Best Regards.
Fujimura.
tdistlists
I'm pretty sure that "monitor session 1 filter vlan 51" will only work if your source ports are trunk ports. In your case they are all access ports.
As for the problem, is your sniffer and/or tool in promiscuous mode?
The sniffer is working in promiscuous mode. The source of the traffic is only one port now. But I still receive broadcast and multicast traffic only.
Best Regards.
Fujimura.
It is also working for voice ports
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swspan.html#wp1200141
Hmmm...
Can you default interface f0/48 and re-configure it as a switchport? I'm tending to agree that the config didn't take. And did you try a different monitor session?
(Thanks for the clarification cadetalain!)
What does show monitor session says?
Below is the output for the sh monitor session command.
IDF-46# sh monitor session 2 detail
Session 2
Type                   : Local Session
Description            : -
Source Ports           :
    RX Only            : None
    TX Only            : None
    Both               : Fa0/14
Source VLANs           :
    RX Only            : None
    TX Only            : None
    Both               : None
Source RSPAN VLAN      : None
Destination Ports      : Fa0/48
    Encapsulation      : Native
          Ingress      : Disabled
Filter VLANs           : None
Dest RSPAN VLAN        : None
Best Regards.
Fujimura.
I took off the spanning tree portfast from the destination port (port 48). In this port, there are only settings for speed (100Mbps) and duplex (full) that match the server´s interface configuration (100 Mbps, full duplex ). I changed already monitor session id to number 2. But the problem still happens.
The output for the sh runn (only show the FastEthernet0/48 setting) and sh interfaces fastEthernet 0/48 are shown below.
speed 100
duplex full
IDF-46#sh interfaces fastEthernet 0/48
FastEthernet0/48 is up, line protocol is down (monitoring)
  Hardware is Fast Ethernet, address is 0024.f7e6.0a34 (bia 0024.f7e6.0a34)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 06:02:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 87142
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     2893 packets input, 301216 bytes, 0 no buffer
     Received 1774 broadcasts (838 multicasts)
     0 watchdog, 838 multicast, 0 pause input
     12422832 packets output, 4710427378 bytes, 0 underruns
     0 output errors, 10 collisions, 5 interface resets
     0 babbles, 16 late collision, 0 deferred
Best Regards.
Fujimura.
Hi Fujimura,
You would need to put the span destination port i.e fa0/48 in vlan 51 (switchport access vlan 51).
Please check if you receive the unicast traffic once this has been configured.
-Reghu.
Hi, Reghunath.
I´ve tried vlan 51 at mirrorred port (port 48), but it didn´t work. I still am receiving only broadcast and multicast traffic.
Best Regards.
Fujimura.
Can you please try to modify your destination command as follows:
"monitor session 1 dest int fa0/48 enc replicate"
and see if there is any progress.
Best regards,
Antonin
