02-02-2023 09:36 PM
We have 2 3750X switches acts as the core , when i try to ping from one to the other , the ping spikes to 1000ms , also the when the users ping the gateway from their PC they face the same , the configuration seems to be fine , what do i need to look for ? each stack was rebooted already.
02-02-2023 10:09 PM
do you have 2 switch stacks? or are they just single 2 switches without stacking?
02-02-2023 10:10 PM
Hello Kasuan,
2 Switch stack , each stack consist of 2 3750x switches and they are the L3 Gateway for users.
02-02-2023 10:42 PM
What is the cpu utilisation on the switch: show processes cpu sorted
02-03-2023 07:23 AM
There are some spikes on the the utilization but not all the time , so from the show process cpu history it spikes to 90 and 100% sometimes but on the time of the ping , the CPU utilization is normal , i checked the platform TCAM and the switches takes only half the available resources
02-03-2023 03:41 AM
Ok, so how your gateways distributed between 2 stacks? how users divided between 2 stacks? or only 1 stack act as gateways? also how is the connectivity between stacks deployed?
02-03-2023 07:24 AM
The switches are connected via port channel , users are divided into multiple VLANS , Core 1 acts the primary for some vlans , core 2 is active for remaining vlans.
02-03-2023 07:07 AM
Any similar issues pinging through the switches, i.e., not pinging an IP on the switches?
Reason I ask, Cisco devices appear to give low priority to responding to ping. Often when a Cisco device is "busy" it can be very slow to respond or not respond to all the pings.
02-03-2023 07:26 AM
We pinged the upstream directly connected WAN Routers and the issue still the same , both switches faces the same issue with 1000ms latency either they ping each other on the VLAN interface or ping the directly connected peers either LAN hosts or WAN routers , the TCAM is not utilized at all , thats very strange.
02-03-2023 08:11 AM
So, to confirm, pinging between two PCs, on same VLAN (both PCs physically connected to same switch stack, or to different switch stacks), or on different VLANs (both with their VLANs gateways on the same switch stack, and on different switch stacks), all exhibit the occasional 1 sec ping response times?
What do interface and MLS stats show on the 3750s?
02-03-2023 08:07 AM
is this occurred suddenly or issue were there for long time? also did you gone through any bugs for current OS version?
