6880 X-LE incompatibility issue
k.elnokrashy1
i have
1- standard table 6880 x-LE  chaise
2- Cisco Catalyst 6880-X Multi Rate Port Card (XL Tables
have any one a solution how to make this two items compatible ???????
the Error that I get is
C6KENV-2-DFCMISMATCH: Module 1 DFC incompatible with Supervisor DFC. Power denied
7 Replies 7
Philip D'Ath
Can you give the output of "show inventory" to confirm the part numbers, and the current software version you are running please.
k.elnokrashy1
the part NO of the chais
is
C6880-X-LE
the part No of the card is
C6880-X-16P10G=
the software ver
S68XISK9N-15201SY
the system stuck as soon as I power it up
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I suspect you're looking at a Cisco RMA situation, because unlike the 6500 or 6507, you don't have a wide choice of line/module cards to install into a 6880.  I would think any 6880 line/module cards should be compatible.
Hey
i am facing the same issue .
how you resolve this issue , please share steps with me .
Rajesh Gupta
I have the exact same issue - what was your resolution?
Problem is 6880-X vs 6880-X-LE supervisors.  The 'LE' is a big difference.
If you have C6880-X-LE supervisor then only C6880-X-LE-16P10G line card is compatible.
Likewise, if you have C6880-X supervisor then only C6880-X-16P10G is compatible.
