A problem with NATIVE_VLAN_MISMATCH
a.m
Frequent Visitor
Frequent Visitor
In the following topology, I was asked to implement the inter-vlan routing on the layer 3 switch MLS.
The activity progress counter shows 100% but I see a vlan mismatch on both of S1 and MLS. I don't understand the reason.
%CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet0/1 (1), with S1 GigabitEthernet0/1 (999).
I checked the configurations but I didn't find any error. Could you please confirm if there is something wrong in the configuration ?
On MLS :
Configurations :
https://pastebin.com/9QHy72Bg
MLS#show interfaces g0/1 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: trunk
Administrative Trunking Encapsulation: negotiated
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 999 (VLAN0999)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: All
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
On S1
configurations :
https://pastebin.com/yPSU0NUn
S1#show interfaces g0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Administrative Trunking Encapsulation: dot1q
Voice VLAN: none
Protected: false
Kind regards.
You are missing two commands on MLS switch.
interface GigabitEthernet0/1
switchport mode trunk
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
12 Replies 12
burleyman
Level 11
Level 11
On the MLS side for the interface put the command: switchport mode trunk
Mike
a.m
Frequent Visitor
Frequent Visitor
So, I can't change the native vlan without being in trunk mode ?
Then you have to remove the command
"Switchport tunk native vlan <>
Deepak Kumar
Deepak Kumar,
a.m
Frequent Visitor
Frequent Visitor
VTP can't communicate the native vlan ?
Deepak Kumar
You are missing a command "Switchport mode trunk"
Deepak Kumar
Deepak Kumar,
Sorry I should have read this more closely.
Did you see the error during the configuration?
Clear the logs and see if the error continues.
After reading everything closer it all looks ok. A trunk will form if one side is trunk and the other to dynamic auto.
a.m
Frequent Visitor
Frequent Visitor
The error persists, is it a bug in the simulator ?
Please attach your lab file.
Deepak Kumar
Deepak Kumar,
a.m
Frequent Visitor
Frequent Visitor
Thank you for your interest.
https://mega.nz/#!MfRTlA6T!Fo1mkMFw5E9DSX-3BcmUCUrESqt8uF0IBDNIUAwbPxo
Regards.
Deepak Kumar
Deepak Kumar,
a.m
Frequent Visitor
Frequent Visitor
The problem can also resolved also when you do, as you suggested before,
Thank you all for your precious help.
Kind regards!
a.m
Frequent Visitor
Frequent Visitor
Sorry, no switchport trunk native vlan 999 doesn't work.
I edited my previous reply.
only, the Deepak kumar's solution work :
